June 3, 200818 yr the z-series would be the LMS killer if it used a linear coil and the fs was brought down alot.the only thing about that is that if you do that, it's an entirely different sub!
June 3, 200818 yr true. I wished i had the knowledge and funds to build a sub. But thats not me. The Z is an awesome sub nonetheless but its not for everyone.
June 4, 200818 yr u know i am curious...This sub costs so much money... so one would think that this might be the end all sub for just straight brutal spl...Well, why does it only have a 3" coil?A 4"coil would be able to receive a LOT more current. It can't be that a 4" makes it so inefficient that a 3" coil has better potential for higher numbers just because it may be more efficient can it?DD has a 4" coil version of the Z with a much stronger motor and larger basket than the present 99 Z; there just hasn't been a need to market it yet.
June 4, 200818 yr that's just crazy knowing that there is something even more powerful waiting if the current Z couldnt keep up with competitors.
