Posted May 30, 200818 yr Will This Battery & HO Alternator Have Enough Power To Power This Whole System!3 Of These (BL15)https://ssl.perfora.net/www.ficaraudio.com/...view.shopscript3 Of Thesehttp://www.sonicelectronix.com/item_9338_H...s+BXi2607D.html3 Of Thesehttp://www.sonicelectronix.com/item_3935_Kicker+PKD1.html1 Of These (Powering Door Speakers)http://www.sonicelectronix.com/item_6519_H...s+ZXi+6406.htmlBattery (For Audio Equipment!)http://www.sonicelectronix.com/item_7343_K...ik+HC+2000.htmlAlternatorhttp://cgi.ebay.com/ebaymotors/240-amp-Dom...itemZ7960516998Alarmhttp://www.sonicelectronix.com/item_7927_V...SST+VS5900.htmlCan I Put 1 Of These Under The Hood?http://sonicelectronix.com/item_8531_Kinetik+HC+800.htmlP.S: Will I Have To Charge Up That Battery (For My Audio Equipment) Everytime I Use It Or Not?Batteryhttp://sonicelectronix.com/item_7343_Kinetik+HC+2000.htmlAnd Can You Please Give Me An Educated Guess Or Estimate Of How Many Db I Will Be Hitting Since I Upgraded Alot Of Things.Also If That 1 Alternator Isnt Good Enough Can I Buy Two To Be Sure? And Do You Think I Have A Good System? What Would You Rate My System From A 1 Out Of 10? Do You Think Its A Good System For A 15 Year-Old?''Hope This Helepd!''
June 1, 200818 yr you would hit a total of 0 db's and i think many people would rate your system 0 on 10 because you dont have a box and a subs output is very dependant on it's enclosure. ok, ok maybe you would hit like 3 db's but you get the point!
