I started a topic about this awhile back and started to get some input about midbass drivers, but that thread died.
I listen to quite a bit of metal and need some real nice mid bass drivers......
no budget...
08 explorer 5x7 w/about 3.5 - 4in depth...
..i can do 8in drivers ....
any help would be appreciated...
:rockwoot:
Edited by y_d0c
  • Replies 60
  • Views 5.1k
hopefully your looking into an active set up, but do you intend to do a 2 way front stage or a 3 way front stage?
What ever driver you choose, deadening and sealing the doors plays a crucial role in strong midbass :)
2 way
This is what ive been told....besides dyna/second skin or whatever im gonna use, do you have any other suggestions for sealant
:rockwoot:
2 way
:rockwoot:
use sheet metal, mdf, acrylic plastic , or hardboard to cover the large holes. I either use silicone caulking or shoe goo ( they make a stronger automotive version of it now ) to attach. Then deaden over top of that. I also tend to do a layer of ensolite ( or some other gasketing foam ) between the door panel and the door it's self. Not so much for sealing as much as for rattle reduction :)
2 way
:rockwoot:
Thank you
2 way? Going to be MUCH harder getting that impacting midbass.
then im gonna have to go 3 way
I'm struggling with my choices. I really would like to go 3 way but it's nearly impossible with my situation currently. I need to find an answer to my quest for 2 way midbass myself. If I was going 3 way though, SLS.
LOL
that's to you.
I have picked Seans brain over and over again. This thread is for you sir. I only chimed in to confirm that if you have an option go active, do it and go 3 way.
What do you have for processing?? That will determine what you can use.
LOL
that's to you.
Much appreciated...:rockwoot:
///M5 In the original thread that i started you had suggested something along the lines of a PPI DCX 730, so i decided to go with that,,,
You have the 730 already? :woot: Although that is only a 3 in 3 out so if you do a true "4 way" (sub included) you will either need to use the sub outs on your h/u or have a little crossover availability on your midbass/sub amps.
If you go 3 way up front, Neon gave you two stellar options. If you go 2 way it will be a different story.
Budget? Other drivers you want to use/need/space for? Amplification?
Oh, and the deadening comment wasn't a joke it is 1000% necessary.
not really any budget restrictions...as far as other drivers go, looking for suggestions so i can get some clear/good quality metal..
when i choose the drivers ill then most likely look for amps...
i didnt take the deadening as a joke :rockwoot:
Next question is, what processing, midrange & tweeters are you using?
i was thinking mb quart or focal comps....
I think the Peerless are currently out of stock though. Should be some used ones floating around.
3 way or 2 way will make the big difference now.
you're right...what about morel or seas
never said anything about processing yet.
pp dcx730
