Posted June 8, 200817 yr can I make a port in a shape of a L and still tune the box too 35 hz. your advise is need badly
June 8, 200817 yr I'm gonna assume your talkin about a slot port, The anwser is yes, In fact most slot ports are the shape of an L do to the length usually has to be longer then the depth of the box to get the proper tuning.
June 9, 200817 yr Author I'm gonna assume your talkin about a slot port, The anwser is yes, In fact most slot ports are the shape of an L do to the length usually has to be longer then the depth of the box to get the proper tuning.Thanks much I am makin the port 3" x 24 and 18" down and 6" across each chamber I hope thats right
