Posted June 9, 200818 yr Bought a Dual 1 ohm Fi BTL 18" Fully loaded.Whats a relativly cheap amp that will power this thing?
June 9, 200818 yr Bought a Dual 1 ohm Fi BTL 18" Fully loaded.Whats a relativly cheap amp that will power this thing?Kicker kx2500.1
June 9, 200818 yr You realize you need 2k-3kwrms to power it right? There is hardly anything in that is reasonably priced that produces said power @ 2 ohms.The only one I can think of off the top of my head right now that would work is the Kicker KX2500.1. It does well over 2500w @ 2 ohms.
June 9, 200818 yr Author it doesnt matter to me as long as i power it Edited June 9, 200818 yr by NofearX18
June 9, 200818 yr Don't forget you can strap 2 amps together to get a stable 2 ohm output.That option is not only cheaper usually but also can obtain more power than a 2500w amp as well.2 AQ1200ds strapped together is just over 2,900w and just under $500 shipped.
June 9, 200818 yr Author Don't forget you can strap 2 amps together to get a stable 2 ohm output.That option is not only cheaper usually but also can obtain more power than a 2500w amp as well.2 AQ1200ds strapped together is just over 2,900w and just under $500 shipped.where would i get these for the best price?
June 9, 200818 yr Author sundown 1500 at .5 ohm possible? with out "mods" or w/e?throw anything out here guys. the kicker is looking to cost me anywhere from $600-800 so im looking for other options aswell.
June 9, 200818 yr Author Don't forget you can strap 2 amps together to get a stable 2 ohm output.That option is not only cheaper usually but also can obtain more power than a 2500w amp as well.2 AQ1200ds strapped together is just over 2,900w and just under $500 shipped.i currently have a Hifonics Bx1605d, can i buy a 1606d and strap it to the one i already have?
June 9, 200818 yr Don't forget you can strap 2 amps together to get a stable 2 ohm output.That option is not only cheaper usually but also can obtain more power than a 2500w amp as well.2 AQ1200ds strapped together is just over 2,900w and just under $500 shipped.i currently have a Hifonics Bx1605d, can i buy a 1606d and strap it to the one i already have?No. If your current amp is strappable, I would just buy another 1605D and strap them.
June 9, 200818 yr Author http://images.google.com/imgres?imgurl=htt...en%26safe%3Doffproblem is that its discontinued. the Bxi1606d is the same thing just newer model
June 9, 200818 yr http://images.google.com/imgres?imgurl=htt...en%26safe%3Doffproblem is that its discontinued. the Bxi1606d is the same thing just newer modelI would contact hifonics and double check. If there were any board changes, they wouldn't be compatible with each other.
