Posted June 9, 200818 yr i am trying to build a box for 4 of my kicker cvx 15's. i called kicker and they recommending using separate 3.5 cub. ft chambers tuned to 38 hz. since this is gonna be my first box build is there an easier less way to build the box without having 4 separate chambers? maybe 2 subs per port or all 4 with one port. it is going inside the car. maybe even a wall design. my available space is 32x56x36.
June 9, 200818 yr i am trying to build a box for 4 of my kicker cvx 15's. i called kicker and they recommending using separate 3.5 cub. ft chambers tuned to 38 hz. since this is gonna be my first box build is there an easier less way to build the box without having 4 separate chambers? maybe 2 subs per port or all 4 with one port. it is going inside the car. maybe even a wall design. my available space is 32x56x36. well ..i guess you could but u could ...as long as you remain within the recommendations..(provided you want to)however u will have to work out your tuning..especially on par with using 1 port per chamber..you wouldnt want any port turbulence neither throwing off of the tuning.winisd and bassbox pro 6 has worked well for me..try it who knows. :drink40:
June 10, 200818 yr I thought you didn't like your CVX's and were looking to replace them?Regardless, you don't need to put them in separate chambers. Put them all in one with one port. Easy and done. Just make sure to brace it.
June 10, 200818 yr I thought you didn't like your CVX's and were looking to replace them?Regardless, you don't need to put them in separate chambers. Put them all in one with one port. Easy and done. Just make sure to brace it.i think he said he has two lincolns... the old one he wants to reuse the kickers... and in the new one he wants to do somthing big and better, either way there should be no reason why you cant just use one big ass port,
June 10, 200818 yr Author that is what i said but the dude from kicker told me 2 use 4 separate chambers.
June 10, 200818 yr Author and yes the cvx's i already have and i want to put them into my 93 lincoln. the 04 is gonna be the one i put upgraded equipment in.
