Posted June 12, 200817 yr I have a good offer on one of these.It seems to be a good amp but im not sure. To be honest i have never heard of it before.My set up is going to be only 1 Dual 1 ohm Fully loaded Fi BTL 18".My problem is i bought the Dual 1 option because i thought that i may get another in the future and with that i could have them wired at 1 ohm and be able to find a amp for a bit cheaper to give them power. what i didnt think of was the amp i was going to use in the time being...i need the minimum of 2000rms at either 0.5 ohm or 2 ohms and this amp does 2000 at the 2 ohms...Anyone have experience or anything i should know about this amp... i saw a reveiw of a different amp from alphasonik on Sonicelectonix.com that said his decided to catch on fire... literally...Is it worth it and will it be good enough to last me until i can afford a bigger and better amp...
June 12, 200817 yr if it caught fire...i wanna say chances are it was due to user installation. but that's just imo Edited June 12, 200817 yr by Basshead
June 12, 200817 yr Isn't Alphasonik related to Audiobahn? I believe so.Why not look for a Kicker kx2500.1? It'll do over 2500w @ 2 ohms.Or if you have a strong electrical system in place, you should look into the SAZ-1500D sale. Run that sucker at .5 and wang away.With a HO alt (180+ amps) and two strong batteries this is what you could look forward to at .5 ohms..5 ohm nominal = 1890 watts @ 71% efficiency (voltage fell from 14.3v, to 12.8v)
June 12, 200817 yr Author Isn't Alphasonik related to Audiobahn? I believe so.Why not look for a Kicker kx2500.1? It'll do over 2500w @ 2 ohms.i can find one for less than $800 and no one seems to want to sell a used on in good condition...i want to get a sundown saz3000d in the future but i screwed up thinking i could power the sub at 1 ohm.... so my Hifonics amp i have now isnt going to cut it until i can get the sundown. this thing seems to meet the RMS of the sub so i am hoping it will do the job until i can afford the sundown.and because i can get this amp for like $350 i think...
June 13, 200817 yr I would really suggest you doin the kicker 2500.1. I think that you will like it better. i found one on ebay for $580 shipped. But again, its not my money. here's the link if you wanna think about it http://cgi.ebay.com/KICKER-ZX2500-1-CAR-AU...1QQcmdZViewItem
June 13, 200817 yr Another option would be to buy two Sundown SAZ-1500D's and strap them at 2 ohms.That should give you just over 3200w.
