You can run XLR cables between the crossover and amplifier, you'll need XLR to RCA adapters going from the crossover to whatever you're using as a line level preamp. What are you using for the other amp(s)?
I dont have anything in mind for the other amps and i am open to suggestions.Going for a simple 2 speaker setup also, and open to suggestions on speakers. Set up is for music.
I'm watching this thread. As soon as I close on my home I will be wanting to build a few different speaker set ups.
Its not much but 400$ is my limit.(thats after the crossover,2500,and clean box)
Was thinking of building a set of these BAMTM. Would they work well with the crossover listed earlier?
Edited by Bobaflob
The ART Cleanbox has a pretty steep roll-off on the low end starting around 35hz. Home Theater Shack has modification details.
-Robert
