Posted June 20, 200818 yr Doing the big 3 on my truck and started to get thirsty. Came inside got an ice cold glass of water and checked to see wat the temperature was outside. Damn, it was only like 80 last week. And that is the indoor temperature in the coldest room in the house with the AC on. Freaking mesierable(Sp) on the inside.
June 21, 200818 yr wasn't all that hot here yesterday temperature wise, but add in 100% humidity, and our heat index was around 100. it was stupid sticky hot in the shop. moved in uber slow moe...wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
June 21, 200818 yr maybe you need to check your AC for problems if its only cooling to 83 degrees. That or your house is like a sieve.
June 21, 200818 yr Author maybe you need to check your AC for problems if its only cooling to 83 degrees. That or your house is like a sieve.The house was built in 50's with out central AC in mind. So a little wall unit was put in the dinning room in the 70's. Thats it. The house is a sieve, Once we turn the ac off its starts till get hot again almost imediadetly. The AC should be replaced, but we are renting and dont want to relace it. 100% humity would suck monkey b*lls. Humidity here was in 30's, so not too bad. I would love to live where it is cold in the winter, and not in the 90's like it is some times here. Guess thats what i get for livin in so cal.
