Posted July 9, 200818 yr Its getting closer to that time, where the monies is almost ready for installation I ran a search, but didn't find anything. I figured its because they're spl subs, but what would you recommend for this bad boys on a daily setup. Thanks mark and anybody else that contributes.
July 9, 200818 yr Why don't you start out by sharing some details about your setup - vehicle, power available, room available, etc...
July 10, 200818 yr Author sure, it will be in a '86 cutlass and will have a 200 alt, with 2 powermasters in back, one up front, but the only thing is I havent measured the trunk but I believe it will have enough room to do whatever or a decent box for both w/ polyfill. thanks
July 10, 200818 yr Author he is about an hour away, so I haven't went down there to do the measuring g.
July 10, 200818 yr Author oh yeah, my bad, power will be 1500 to 2000 rms a peice. sorry, and if it is 2000 we will mount them inverted like you recommended. thanks again
July 13, 200818 yr Is it for burping or daily? If you can get the measurements of the area that would help a lot...
