Posted July 10, 200817 yr hi,i have a pair of Adire Audio Extremis lying around for more than a year already. As i want to install them, what tweeters are best used or matched/suitable with it?planned to power with JL Audio 450/4 and using the onboard crossover.thanks
July 10, 200817 yr Check out Madisound. Vifa XT25 are great for the money, but sometimes not the greatest off axis tweets.I bought the SEAS, and couldnt be more happy. They blend well with my Morels and they were only 65 for the pair.http://www.madisound.com/catalog/product_i...roducts_id=1466
July 10, 200817 yr Could also get in on the Hybrid-Audio group buy at 25% off and pick up a pair of L1 or L1 Pro's
July 10, 200817 yr You need something that plays really, really low. Perhaps using a 2 or 3" mid and no tweet would be a better option. Those are really effective as midbasses but not what I would call mids.
July 11, 200817 yr Author Thanks for the feedback guys what kind of tweeters do Ascendant have?I'll check out Seas & Hybrid Audio tweets. The Scanspeak Revelator is nice but darn expensive.What is a good non-ear piercing Seas tweets?///M5, you're saying that the Extremis mid-range performance is not really that good that it is more suitable for use as midbass driver?To use 2" or 3" driver is mainly for horn setup yep?
July 11, 200817 yr Author The d2904/6000 has an Fs of 750 hz, IIRC. Nice, robust tweeter.i would guess that is Scanspeak tweeter. How low can it be crossed?Just wondering, what is so good about Scanspeak Revelator tweeter?thanks
July 11, 200817 yr Anything lower than 1100hz on my D2904's and they complain.I wasn't recommending a 2 or 3 for use in a horn, just a full range so that you actually have midrange as well. You "can" use the Extremis as a mid, but it excels at midbass and I'd try and keep it there.
July 20, 200817 yr Author i have the Adire Audio Koda component set. If i put the Extremis as the midbass driver here in 3-way setup, will it be ok?or is it too much to ask from 6.5" driver to be a good midrange
July 22, 200817 yr Author how much does the CDT ES-02 tweets cost?also is this tweets ok? Scan-Speak D3004/6600 Textile dome tweeter http://www.madisound.com/catalog/product_i...roducts_id=1738the freq. response curve shows that it can play lower than 1khz
July 22, 200817 yr Never look at the freq. response when determining how low a tweeter can play.At VERY minimum 2*Fs with a very sharp high pass filter. Personally, I wouldn't run a tweeter at lower than 2.5*Fs... but then again, I've never blown a tweeter before. P.S. You did look at the dimensions & price of that sucker right?
July 22, 200817 yr only horns I have personally heard have been image dynamics - they have all sounded nice, but the best I have heard is the cd2's in a dodge.....one of the best sounding cars I have ever heard....also had the most realistic drums I had ever heardwhat horns do you recommend
July 22, 200817 yr how much does the CDT ES-02 tweets cost?also is this tweets ok? Scan-Speak D3004/6600 Textile dome tweeter http://www.madisound.com/catalog/product_i...roducts_id=1738the freq. response curve shows that it can play lower than 1khzdo you want to spend 220 per tweeter?
July 23, 200817 yr Author the Image Dynamics horn cost to me is kind of out of my budget.The Scans tweeters are kind of high to me as well but seems nice
August 10, 200817 yr Author will the Alpair 5 works well with the Extremis? It is a 2" driverhttp://www.creativesound.ca/details.php?model=ALPAIR5GREY
August 10, 200817 yr Never heard that one, but personally I'd use a 3" full range instead of a 2. For you that compromise on the top end might not be what you want.
August 10, 200817 yr Author thanks for the reply.will adding a tweeter help? say going for 3-way setup.if say use a full range driver eg. CSS FR125SR 4.5" driver, a tweeter is still needed as well?
