Posted July 25, 200818 yr Ok I have a basket out of a 12 and a motor out of a 10 I wont to use together to make it a way better 12 then get it reconed. I was able to unbolt the motor for the 12 but I still can
July 25, 200818 yr Author ok got the bolts out of the 10 and cant get the motor off anyways. any one have any ideas or is there some top secret way there held on?
July 25, 200818 yr Besides bolts, there is usually a bead of glue holding the motor to the basket. When I rebuilt a TC Sounds sub, I had the same problem. I just used a thin blade screw driver like a chisel and tapped the seam between the motor and the basket. About the 4th tap, the screwdriver went into the seam and I was able to pry the two pieces apart.-Robert
July 26, 200818 yr That first sub was an MA Audio Hardkore basket, right?I don't know what the 10" basket is.
July 26, 200818 yr Unless you really care about the cosmetics being perfect:1) Get large flathead screwdriver2) Set woofer down and grab the farside of the basket3) Put screwdriver between frame and motor4) Push down on the screwdriver like a lever until you hear a pop.Do it quick and hard and you wont even leave much of a mark on aluminum baskets. I do it all the time.
July 26, 200818 yr Author The ten is a SP10 made by the swan speaker company it was blewn when hooked to a wall outlet. heres a link to the sub http://www.swanspeaker.com/product/htm/view.asp?id=50Yeah and the 12 was an 2002 MA audio subwoofer 1000watts duel 6 ohm coils. Edited July 26, 200818 yr by 944guy
July 26, 200818 yr you might have a easier time getting a recone if you just buy a standard 12 spoke basket with the recone.i don't know but the 12" basket you have may not have standard spider, and surround landing heights.
July 27, 200818 yr Author Well I had the whole thing hooked together and guess what some punk from my work knocked it off a shelf and broke the motor and messed up the basket. So I
