Posted August 2, 200817 yr even though i bought the equipment..my dad is gnna be pissed............1 kicker 10l7...........1 pos american pro 1200 watt amp..mind you it sounds awesome with a kicker !!!i was just playin d4l laffy taffy.played normal....started over the song raised the vol to 6 ..and as soon as the bass was about to hit it played only on my 6x9 's ..the sub wasnt playing ..........i pulled my backseat back and saw the amp light wasnt on....................what to do????????i wpuld check the fuse if i had time but my dad would see me and ask what hapened...ill try for him to play it when hes goin to work then call me and ask what happened."ill be "what did u do" then ill bring it home and follow you guys advice.......thnx.
August 2, 200817 yr may be in protect, or dead! Did you touch the amp to see if it was hot? check all your fuses and wiring. Are your gains set properly? Could have possibly clipped the sub and burned the coils?
August 2, 200817 yr Author may be in protect, or dead! Did you touch the amp to see if it was hot? check all your fuses and wiring. Are your gains set properly? Could have possibly clipped the sub and burned the coils? well its been playin this way for a year and a half.........dont think itll go crazy tnight....cool as a cucumber........and smelled no coils..l7 cone cold.
August 2, 200817 yr Author just wish me luck tmorrow..lol......if it died.it was a chit amp anyways (price) but worked well............lets see what happens
August 3, 200817 yr Author well...good report...i starrted by taking off my grnd and proceeded to check the power fuse......all good....then i checked connections...a ok.......then i checked the amp fuse .....good...so i was like wtf .........then i shoved em back in and pulled out the bass remote and put bk on my grnd once again ....bingo!!!still no idea what i did .but it worked!!!!!!!!!!!thanks all at ssa!
August 3, 200817 yr Author also ..what do suggest went wrong??.somehow the instrumental of d4l was very strong to the point of distorted(just audible enough to hear stained frequencies)..could this be the prob?
August 3, 200817 yr probably a connection vibrated loose, fixed when you reinstalled the ground/bass remote/whatever else you fiddled with.glad you got it to work!wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
