Posted August 7, 200817 yr I did a bit of searching, and it seems that a few people are against the KLM Copper Clad Aluminum cable. I plan on getting the 1/0 KLM cable for my Sundown 1500D for a 15ft run. KnuKonceptz claims that their 1/0 CCA will do fine as long as you're not running gobs of wattage. Anyone think otherwise?Thanks,Trevor
August 7, 200817 yr Those people that are against it are ill informed. More than adequate for that amp, just ordered some of the same for my install consisting of the same amp plus 3 SAX-100.2s. I'm not in the least concerned.
