Posted August 8, 200817 yr I have a Hyundai XG-300 (ya i know they are not that common) and I'm looking to do the big 3 upgrade with 1/0awg but before i do i want get get a new alternator rather than the stock one that i have(120 amps) Only problem is that i cant find an alternator made for my car that does any thing over stock and i need at least another 80 amps at the minimum..basically im trying to power a btl 15 or grab a re audio xxx 15..pretty much i need to get 2000w + rms out of my charging system.(i am aware of the extra batteries needed)...my question is would any H.O. alt. i find work fine with my car or should i just buy a new stock alt. and get it rewound and altered to put out more power..thanks in advance
August 9, 200817 yr Author he couldn't help me with my situation..i would just go to a car shop around here but i am in alaska and there not much up here
August 9, 200817 yr he couldn't help me with my situation..i would just go to a car shop around here but i am in alaska and there not much up hereDid you try Powermaster? Iraggi? Ohio Generators?
August 9, 200817 yr Author yea..would any universal alt work or would tthe bolt patterns make a huge difference
August 9, 200817 yr yea..would any universal alt work or would tthe bolt patterns make a huge differenceI'm not sure, I'm not the foremost expert on alternators, and I have no idea whatever that car is, never heard of it.
August 9, 200817 yr Author http://images.google.com/images?q=hyundai%...sa=N&tab=withere is the link for wut they look like
August 12, 200817 yr www.mechman.com he did mine and i own an 04 hyundai sonata... probably the same alternator im guessing. I got a 250 amp alternator
August 13, 200817 yr try this also http://www.db-starter-alternator.com, and the other option is to install a volatage regulator and modify the diode plate circuitry, that's what we do here in NY.
