Depends on what you want to do with it really and if you plan to power it in car or out of car.
Goldline makes a few quality pieces. Their older gear wasn't horribly accurate, but it would still work to achieve a flatter system respons
Ideally, you should look into a USB interface and a good measurement mic and then get an application for a computer. This will let you look at the bigger picture with Phase, Time alignment and EQ.
Yeah I was thinking about using a computer, what are some recommended mics and apps?
Thanks
-Mike
well.. heh I can recommend extremely nice mics, but for car purposes the Behringer ECM8000 should be perfectly fine.
As far as interfaces go, pretty much any USB microphone pre-amplifier at around $100 should have decent enough specs.
PM sent
