Posted August 12, 200817 yr Hey first off this forum is badass, learned alot so far!! Well I'm building a new box for (2) 15" DC lvl4/wlvl5 dual 1 ohm coils. This is going to be my 10th box in my nissan frontier so far...havn't found exactly what I'm looking for, hopefully this'll be it. However this is my first L shaped slot port box, so I need some help guys. I've searched and searched and did some more searching and I can't find exactly what I'm looking for. I don't want to just post my problem them have somebody fix it for me, I want to understand this. It's driving me nuts that I just can't grasp it. Could someone give me exact measurments and explain why, so I'll have the knowledge to be able to reproduce this without help. Alright measurment are all internal,H - 24W - 49D1 - 10D2 - 14Total - 8.17 ft^3Board thickness - .75After braces and sub displacement - 7.71ft^3Looking for 34 hz.Square inch 90Port opening - 6X15 - InternalHere are some crude illistrations of the box, What I need is length of each board needed to build port; and why.I've got a saz-3000d on the way from here, just bought it last night....can't wait.Any info given would be great and much appreiciated!!Thank you for your time,Dustin
August 12, 200817 yr Author Oopps the measurment on the port illistrations are incorrect it should be 6X15 inch internal port opening.....my badDisregard, Fixed it. Edited August 12, 200817 yr by 04nissanfrontier
August 12, 200817 yr Author Well, can someone double check my numbers that I came up with?I've got 6X15X16 slot port34hzvolume after port displacement 6.70 ft^3
August 13, 200817 yr yes, measure your port down the center line. some people can sketch it out on paper pretty quick, im faster sketching it on a scrap piece of wood with a framing square. it helps seeing it full size
August 13, 200817 yr Author yes, measure your port down the center line. some people can sketch it out on paper pretty quick, im faster sketching it on a scrap piece of wood with a framing square. it helps seeing it full sizeWhat up man...damn you're all over the place! I guess I just need to learn how to use bass box pro, to get my port length right the first time. But until then I guess I'm just gonna put the longest port I can fit in there, then work from there.
