Posted August 13, 200818 yr Got these for free and I need help identifying these for a budget build in my Dad's neon :/. Both aren't going in, just trying to figure out which one to use and what model that JL is... thanks for the help! Edited August 13, 200818 yr by frankum
August 13, 200818 yr The JL is aW1 or W0, but I don't believe the W0s had the vented pole.The CV is a CLASSIC! I would kill to have a pair of XL12s in mint condition! They like larger vented enclosures only.CV specs:Type: Standard one-way driverShape: RoundPiston Type: ConePiston: Non-pressed kraft pulpFrame: Die cast aluminumVoice Coil: 2 in, aluminum coil bobbinFs = 30 HzQms = 4.443Vas = 152.9 litersXmax = 3.988 mmXmax (parallel) = 3.99 mmXmax (series) = 3.99 mmSd = 538.6 sq.cmQes = 0.235Re = 3.4 ohmsZ = 4 ohmsPe = 125 wattsQts = 0.2231-W SPL = 96 dB
August 13, 200818 yr Author Right on. Which would you use? I'm going ported for sure, just need to figure out which one. The CV is clearly in much better shape.
August 13, 200818 yr i would use the cerwin vega and the jl looks like one of the lower end models like the w1 not quite sure but its def one of the lower ends w0 w1 w2 one of them
August 13, 200818 yr Depends on what you are looking for. The JL will work well with low power and 1 cube or slightly more sealed. The CV on the other hand, I believe will need around 2.5 cubes at least. Let me plug the numbers right quick.
August 13, 200818 yr Author Okay. Neon trunk to be exact. I'm helping a friend, and it's his first build, so sealed preferably.
August 13, 200818 yr jl is a w0 or a w1... i think the saround looks old. it will prolly crack and break, i would use the jl motor as a screw keeper, and or a soildering iron stand
August 13, 200818 yr The JL is definitely a W1v1. The W0 had a really pronounced bump in the backplate. Looked like a volcano without the crater portion. 1 CF sealed is about right for that sub maybe a little bigger. It also only really wants a max of 150w. Great old budget sub. I still have a 10W1 from 1991 that is in perfect shape. Was my first sub actually.
