Posted August 13, 200818 yr Ok I am thinking about purchasing two DP 15's but don't know exactly which coil config. I should go with. Will the amp be strong enough for these at 1 ohm or should I get dual 2's and run the amp at .5? Thanks in advance for the help...Oh, btw, this is for a daily application that will be tuned to 30hz.
August 13, 200818 yr 1 ohm should be plenty. The DP's are pretty efficient buggers.but .5 wouldn't hurt if you have the electrical. Could always turn the gain down.
August 13, 200818 yr Author 1 ohm should be plenty. The DP's are pretty efficient buggers.but .5 wouldn't hurt if you have the electrical. Could always turn the gain down.would it be an audible difference from 1 to .5 ohms? or would I just be creating more heat and losing efficiency?
August 13, 200818 yr That has a lot to do with how your box is made and what your electrical consists of. If you're at .5 ohms and your voltage drops.. the subs and amp are going to get a little hotter than normal
September 20, 200817 yr hey is the 40.1 .5 ohm stable? i have 2 15" BTLs dual 1 ohm. what is the rms at .5 ohm?
September 20, 200817 yr yes it is stable. The better question is your electrical stable, thats the determining factor. power @ .5 = more than enough
September 21, 200817 yr yes it is stable. The better question is your electrical stable, thats the determining factor. power @ .5 = more than enoughnot yet... im in the process of getting everything. it takes a while when your in college... money is tight
September 21, 200817 yr i understand that one. i just graduated, and I'm going back for extended courses.
