Posted August 22, 200818 yr im looking to change my setup. if i go the bl route, my box cuft will be 5-5.4cuft total including port area. if i go btl route, the box will be about the same total. they will be powered by a zx2500 which in the birth certificate says 2700 (if that matters)now i want to know which will be louder. this will be for daily use in my dodge charger. i currently have 2-15" L7's sealed in a 4.2cuft box and it pounds, but i just want to change it up. plus, i have a feeling that i can get louder than it if i go the FI route. thanxim also open to other suggestions.
August 23, 200818 yr im looking to change my setup. if i go the bl route, my box cuft will be 5-5.4cuft total including port area. if i go btl route, the box will be about the same total. they will be powered by a zx2500 which in the birth certificate says 2700 (if that matters)now i want to know which will be louder. this will be for daily use in my dodge charger. i currently have 2-15" L7's sealed in a 4.2cuft box and it pounds, but i just want to change it up. plus, i have a feeling that i can get louder than it if i go the FI route. thanxim also open to other suggestions.first off welcome to ssa. you should visit our sign in... well you sure do have a choice to make.. with 2700 watts you can do either one.... the choice really comes down to budget and and space...... what is your charging system look like? and what kinda music do you listen too.... and lastly what are your goals.... no need to post many times on the same question.... just pick a section that matches your question.. and post once..
August 23, 200818 yr Author alt- 160 ampsbattery- stock 760ca, kinetik 2400, and kinetik 600music- i listen to rap, drums n bass, technogoals- to be louder then i already am. i figured if i go ported i should be louder, then my 2-15 L7's which are sealed in a 4.2cuft box.space- i can probably get 5.2 cuft totalim open to ther suggestions
