September 4, 200817 yr son please....get a bigger amp. u have alot of potential there. 600 watts? at least u could get a hifonics 2000 watt and get a lil over 1000 to both of the subs. lol
September 7, 200817 yr Author son please....get a bigger amp. u have alot of potential there. 600 watts? at least u could get a hifonics 2000 watt and get a lil over 1000 to both of the subs. lolNew amps here on Wednesday, along with new vids.
September 7, 200817 yr haha, nice man, i got a 89 ranger to work with, pretyy close to the same thing
September 7, 200817 yr Author haha, nice man, i got a 89 ranger to work with, pretyy close to the same thingPretty close.The '89s have the flatter front and share lights with the Explorer IIRC.However, engine and electrical should be the same.
September 7, 200817 yr yup any idea where i could find any clear lights for them? ive been looking forever and cant find it anywhere
September 8, 200817 yr Author yup any idea where i could find any clear lights for them? ive been looking forever and cant find it anywherehttp://www.jamesduff.com/broncoII/broncoII.htmlBronco Grave Yard.Only two places I know off hand that might.
September 9, 200817 yr Author OK. I can't keep this secret anymore since I need your guy's help.Ordered these Friday, hopefully shipped today.I'm going to wall it over Christmas break.I was going to 4th Order it but a BR will have a higher and flatter output.I want to tune it to 33hz like the box I have now, but I hear from several sources to tune higher, to 35-40hz.I love the low, lows, The C&S Version of Put On in this Vid low.Low notes are 27 and 20hz.What should I go with? Edited September 9, 200817 yr by Bigpimpin91
September 29, 200817 yr Author Here's the plan as of now. Circles are the outer diameter of the subs, not just mounting holes.All Thread Rod Between every sub and across the box through the port. Edited September 29, 200817 yr by Bigpimpin91
September 30, 200817 yr Author very nice sketch up.what did u use?What do you mean by that?The sub model I found on Google under Sketchup Models.Are you going to be using more MJs? I'd get the new version.Yup.4 MJ18's in a Bronco II.
September 30, 200817 yr id split the port into two ports tune it higher to like 35hz great for music then have a cover for one port for a retune for when you want low lows like 26hz tuning. on the video it seemed like you where unloading a bit on the lows and that kills output a lot.
September 30, 200817 yr Author I'd recommend a double baffle. Even w/ allthread.Baffle is doubled with a flush cut.That was the purpose of the bottom up view. Minus the bottom right sub which was placed wrong.
October 2, 200817 yr Awesome I wanted to get 4 MJs but my paycheck blows, so im getting 2 GL You conviced me that I want these subs now
February 8, 200916 yr Author 16hz Action. Slow frame rate FTL.New Track I'm working on.Upgraded Mirror Trick.Napkin Trick. LoL More coming.
