Posted August 27, 200817 yr pics :http://pierceaudioproducts.com/forum/index...opic,162.0.html This is designed to take both of my SAZ 3000d amps DAILY / Street Beat
August 28, 200817 yr Author What size vc?4" DVC 1ohm / 8 layer Flatwound alum w/ copper cladingpole piece was custom vented and gap was machined to fit the over sized coil, normally that use 4 layer coils...
August 28, 200817 yr Author wont know till i get the T/s im having the leads Hardwired / no terminal......
August 28, 200817 yr Author should look like thisthose are pics of the 21" sub there building ( different sub )
August 29, 200817 yr nice fiberglass. you sure that its balanced correctly? would be a shame if not.. wouldnt want one side of the suspension to wear differently...whatever i guess, your sub, your epic fail.
August 29, 200817 yr Surely it wouldn't matter THAT much, he wont keep 6k going to that at all times. He would very unwise and destroy his hearing very quickly!
August 29, 200817 yr nice fiberglass. you sure that its balanced correctly? would be a shame if not.. wouldnt want one side of the suspension to wear differently...whatever i guess, your sub, your epic fail.Geez man. Why so negative? I'm sure he knows what he is doing. Stop criticizing and just sit back and watch his project.
August 29, 200817 yr nice fiberglass. you sure that its balanced correctly? would be a shame if not.. wouldnt want one side of the suspension to wear differently...whatever i guess, your sub, your epic fail.Geez man. Why so negative? I'm sure he knows what he is doing. Stop criticizing and just sit back and watch his project.X2. He didn't do the glass himself, the manufacturer of the sub did. I forget his name though...
August 29, 200817 yr nice fiberglass. you sure that its balanced correctly? would be a shame if not.. wouldnt want one side of the suspension to wear differently...whatever i guess, your sub, your epic fail.Geez man. Why so negative? I'm sure he knows what he is doing. Stop criticizing and just sit back and watch his project.X2. He didn't do the glass himself, the manufacturer of the sub did. I forget his name though...pap. and not really negative so much as realistic. i really want it to work for him:) would hate for him to be out money (although, pap WOULD make it right, im very sure:))
August 29, 200817 yr Author Thank you all i have TOTAL FAITH in PAP ... John Rules when it comes to building Custom subs this is the 4th sub iv had them custom build and every one was A top of the line ( Jugernaught ) THEY HAVE SPOILED ME AND NOW IM ACCUSTOM TOO HAVING SUBS NOONEELSE hasmine look like the other subs from the front !!! but its whats underneeth that countsi.e. the Wmd2 w/ carbon fiber conesdid a 154.3db not even broke in standard sub on right / my version on the left ... did a 151.7db all by itselfhoneycomb cone w/resin / quad stack magnets / quad spiders / 4k tensel leads / custom pole venting etc etc etcoh well you get the point
August 30, 200817 yr LB, read the thread over on PAP's forum again. It's actually a 4 layer coil, an 8 layer coil won't fit in the gap. Edited August 30, 200817 yr by Patrick Bateman
August 30, 200817 yr should look like thisthose are pics of the 21" sub there building ( different sub )That's a 15" basket, the 21" basket they have looks the same as IA's 21.
August 30, 200817 yr why not just buy a BTL fullyloaded that would be easy.That would just take all the fun out of it. Everyone has fully loaded btls, he has his own custom made sub THAT NO ONE ELSE HAS.
