The port caculator
http://www.carstereo.com/help/Articles.cfm?id=31
and other online calculators use the xmax in the calculations PURELY for the purpose of determining how much port area there should be.
Tuning freq is dependent on box ONLY, not the driver.
Port area for this box should be about 120+ in^2...
If you want me to, I will draw up plans for you. Free of course.
Just to back up your work or to work off of.
You will love these subs if you get them in the right box...
And I would recommend 30 htz for tuning.
My draw ups look like this (i like doing it all by hand)
And just for fun here is my box build log if you wanna look at it (took only two days to build this box: one day cuts and one day assemble and paint):
http://www.soundsolutionsaudio.com/forum/i...showtopic=20625
Edited by nick_19
  • Replies 123
  • Views 14k
The port caculator
ye if u could:) but i still need the subs facing up and the port facing back in the middle and keep the measurements. 19" deep and tall 44" wide 25" long from back seat. heres tha new plan
i got the front peice drawn. both side peices. top and bottom peices too gotta get a half a sheet of mdf to finish. i dont like using a hand skillsaw cuz it can messup easier and make it even a little off.. any tips to help keep it straight? if not im going to try to use one of my friends dad's table saw
Edited by RobClay
Look at the pics of my box build. That is the best method. Those cuts we made were soooo straight. I'd recommend doing it like that
like clamp a yard stick beside the cut line and cut beside that to make sure it stays straight? i get what ur talkin bout
Here. My specs are flawless... trust me.
I did all the math 3 times. By hand, no online calculators...
I took my time to do this for you, so trust me, it's right.
I can also draw up cuts for ya if you want.
I did a 3 inch port, then 6 inch combined in order to keep the math the same... otherwise it would get too complicated.
I couldn't get exactly 30 htz for tuning, but I got right under it.
Does this look good for you?
3.7515 ft^3 net per chamber
29.79 htz tuning freq
Edited by nick_19
thanx man:D not many people would do that.. one question and ye it looks good ill go with this design. what is that number by the 19 on the left side of the drawing?
The height!
Lol.
I'll draw you out some cuts and stuff if you'll use this plan.
The outside numbers are the outer dimensions.
Use a table saw, makes life a lot easier, especially with a good fence and extension table for the sheet :)
The height!
Lol.
nah lol i ment what does the number say:P i can hardly see it
oh 17.5 lol
that is inside dimension
Edited by nick_19
oh 17.5 lol
o haha aiight the rest of the measurements are 10.75, 23.5, 17.3, 17.5, 44, 19, and 25.. tell if their all correct i just put them in random order
yupp.
but that one 17.3 is a 17.5
I'll draw you up a cut sheet when i get time...
classes are kickin my butt.
i'll try to get them done by late tomoro night
aight here we go
put it together like i showed w/ the joints.
tips:
put together the two sets of two port pieces together w/ screws and glue b4 you screw them onto the box. It makes a funky angle that is hard to get to w/ your drill.
put together the box in the order i did w/ my box... i find that to be the easiest: put it all together on the 'bottom' of the box, then put the top on.
i'd recommend taking another 'top' piece and put it on top of the top to make a double baffle.
any questions, just ask me.
Gross-11.08
Gross per chamber-4.16
Tuning-29.79
Net per chamber-3.75
Port area-104 in^2
Edited by nick_19
yupp.
aight here we go
tips:
Gross-11.08
Tuning-29.79
Port area-104 in^2
wow man. thanx for all the help and all that this is gonna help me alot. and all the tips. ill probably start tomorow. or sometime soon. ill keep you updated on tha pics and progress:)
but i really do appreciate your help, (sorry if i keep sayin it over and over again haha)
Lol it's all good.
And I check this topic everyday, so if you got any questions, just ask me.
You should have minimal flex w/ two baffles. If you have extra room, you can double up on any side. You cannot do internal braces, because that would throw the airspace and tuning off. If you decide to double up a side, just add the sheet on the outside of the box. Like put it together w/ the pieces I listed, then take the measurements of the outside and make the extra pieces. These subs are only 600 RMS a piece, and I think single .75 will work great, but doubling always helps if you can!
Pics are always great!
Edited by nick_19
Lol it's all good.
sounds like a plan. i might just double the top part. im using 3/4 mdf i hopin thatl be good enough
ok heres some updates on tha build. tha box is close to being finished. heres some pics
started cuttin
most of peices cut out
optima redtop
box as of now
enjoy:DD all thanx to nick19 thanx for all your help man
It's the, not tha.
Nice looking build though !
haha sorry its just where im from thats how i talk. but thanx
we'l be puttin 0 guage wire soon and the second amp and tha t1's like this week;) so keep an eye open for this build
and here's some more updated pictures:DD and the dude in tha picture is who im buildin it for..
i think its turnin out very good u tell me:))
some more updates of what ive done today:D
