  • Replies 103
  • Views 9.5k
yeah, i never get on there though, im always on here or texastruckscene or performancetrucks
Ohh alright. I spend a lot more time on here and RoE, especially when I'm putting most of my income into stereo equip. at the moment, haha.
gotcha.
anyone else have any suggestions or guidelines?
sub up ports to the side... much louder at the head rest (MECA Style)
any good box designing programs i could use to figure out the specs for it? or possibly can you help?
yeah I'll get you some rough dimensions... it'll take a couple
48 x 20 x 18
gives you roughly 6 cubes after all displacements (pending on how heavy you brace, dimensions only good for a single layer of .75 inch material)
w h L
17x5x27 slot port gives you roughly 30 hz (port consumes 1.66cubes) (I allowed .5 cubes for woofer and bracing)
fire sub up on pass side and port towards drivers, flip box around to be louder on the other side
Id suggest that you atleast double up the baffle
loud side=port side
Usually if you roll down the window on the sub side you gain a ton of output on the portside headrest... open the door and it gets even louder... I use that design to show off at car shows. I let the people get in and shut the door then I just leave mine open...
*all shut up my pass headrest meters about 1db higher than the drivers (my ports are aimed at pass side)
Edited by rushnrun
possibly tune it to around 33-35hz
how much shorter would i need to go to do that?
about 15inches long
you could increase port height to 6 and change the length to 22 for more port area and a 34hz tuning
still up for other suggestions, sometime next week i'll choose a design.
alright, 1 sheet of mdf should do the trick?
1 SHEET won't do it... I think the best you could end up is a sheet and a half. one sheet will cover the top, bottom, front back and sides the other sheet will be needed for the second baffle layer, port, and any bracing....
the sheet will be 49x96x.75 you'll need:
2 20x48
2 16.5x28
2 16.5x18.5
1 16.5x(port length)
2 (port length x port height)
2 20x48
2 16.5x28
2 16.5x18.5
1 18.5x(port length)
had a mistake on the other.... wrong port width... these are right.
side firing port wins, bout to start measuring and cutting tomorrow if work and weather permits.
well have fun building :)
I assume you undersand how the port goes together..
these dimension make the box a little easier to build (you don't have to cut out the opening for the port this way)
If you don't understand how it goes together I can make a quick sketch.
2 20x48
2 16.5x28
1 16.5x18.5
1 (16.5 minus port heigth) x 18.5
2 (port length+.75") x (port height)
make sure you post pics :)
2 20x48
2 16.5x28
1 16.5x18.5
i kind of have a idea, but i wouldnt mind a image just so i do it right.
I'll be building a box tomarrow with the same basic design.. If you want I can post some assembly pics..
doesnt matter to me, probably wont be able to start working on it, till a few days, damn hurricane. sub is supposed to get here next tuesday, and about that time, the hurricane should hopefully be done for so then i can go out and start cutting, if i dont today.
I'll get a pic posted in a sec... takes forever to upload on work's dial-up :)
dang, didnt even know dial up was still in use...
yep,, it moves at a blistering 14.5k/sec :)
doesn't matter, I've got all day.... well until 4 :)
haha, im bout to have to go grab some supplies and what not for this hurricane.
