Posted September 12, 200817 yr I've never installed anything other than coaxials in the rear deck of a car...However with my new setup, I'm thinkin of going with 4 Mach 5 MLi-65s. theres going to be tweeters and x-overs aswell.I'm going to be putting one in each factory location. the other two will either go in the pillars, in the dash, or somewhere behind me ( reg cab truck, isn't a rear "stage" useless?)I'm wondering how to wire it up. just been looking at amps online and I'm wondering how it all connects.I have a Pioneer DEH-4900IB for a headunit, and won't be running active.... just a two way component set.
September 12, 200817 yr I'm curious as to where you are going to find the passive crossovers for those drivers.
September 12, 200817 yr Author I'm curious as to where you are going to find the passive crossovers for those drivers.Well.. if I don't use the MLi-s I'll be using a component set, that comes with x-over, tweeters, midbass whatever.. something like the PG RSds or CDT CL line...
September 12, 200817 yr I've never installed anything other than coaxials in the rear deck of a car...However with my new setup, I'm thinkin of going with 4 Mach 5 MLi-65s. theres going to be tweeters and x-overs aswell.I'm going to be putting one in each factory location. the other two will either go in the pillars, in the dash, or somewhere behind me ( reg cab truck, isn't a rear "stage" useless?)I'm wondering how to wire it up. just been looking at amps online and I'm wondering how it all connects.I have a Pioneer DEH-4900IB for a headunit, and won't be running active.... just a two way component set.nm I didn't catch the last line. so let me try to understand this: 4 mli-65's 4 tweeters plus a 2 way component set, all run passive, off a 4900ib? I don't think I'm getting this right, please explain in more detail.
September 12, 200817 yr Figure out what equipment you are going to use, because it will drastically change the answer to the question.Personally, I think you need to start simply... simplicity seems to be lost among some. 1 midrange per side, 1 tweeter per side.
September 12, 200817 yr ok, so its basically either/or. You would need to run active if you used the mli-65's.
September 12, 200817 yr Author Figure out what equipment you are going to use, because it will drastically change the answer to the question.Personally, I think you need to start simply... simplicity seems to be lost among some. 1 midrange per side, 1 tweeter per side.yeah.. I just dont want the rest of the sound to be overpowered by the bass of two SPL-12s...
September 12, 200817 yr Author ok, so its basically either/or. You would need to run active if you used the mli-65's. I can't remeber what active means.. and I think I can't do it with my deck...
September 12, 200817 yr ok, so its basically either/or. You would need to run active if you used the mli-65's. I can't remeber what active means.. and I think I can't do it with my deck...You can't. Active means filtering is done prior to amplifying the signal. Each speaker needs its own amplification channel & processing channel capable of proper filtering.
September 12, 200817 yr Author One very simple solution to that predicament.Yah... I'll search what active means...edit... err... what you talkin about? Edited September 12, 200817 yr by Gearstix
September 12, 200817 yr the difference between the active and passive is where the drivers are crossed over in the signal path: passive crossovers are located between the amplifier and the speaker, active crossovers divide frequencies before the amplifier. Active setups consist of a good head unit, amplification for each channel (tweeters, midrange/midbass, subwoofer) processor, and individually purchased speakers like the mli-65's. passive setups are component sets, which I think you would be happy with.
September 12, 200817 yr Author ok, so its basically either/or. You would need to run active if you used the mli-65's. I can't remeber what active means.. and I think I can't do it with my deck...You can't. Active means filtering is done prior to amplifying the signal. Each speaker needs its own amplification channel & processing channel capable of proper filtering.So what do you reccomend? I know you said 1 mid 1 tweeter per side..I'm sorry...I'm tired and I'm dumbner than a plan right now. Edited September 12, 200817 yr by Gearstix
September 12, 200817 yr Author nevermind blitz.So what you guys are saying is I should get a passive component setup?
September 12, 200817 yr Author and after looking at the PG RSd's x-over I think I figured most of it out...rcas from deck>amp, amp>crossover, crossover>woofer/tweeter.
September 12, 200817 yr you got it check on ebay for Infinity Kappas, you can find a great price on them and I believe they are much better than the PG's. the tweeters are a little sharp for my tastes but you might like them. Proper amplification and they would sound fine with your SPL 12's.
September 12, 200817 yr Author you got it check on ebay for Infinity Kappas, you can find a great price on them and I believe they are much better than the PG's. the tweeters are a little sharp for my tastes but you might like them. Proper amplification and they would sound fine with your SPL 12's.http://www.sonicelectronix.com/item_13969_...ppa+60.9cs.html those?
September 12, 200817 yr yep those, but check here Ebay I just installed a set in my girls car, sound very good for the money.
