Posted September 18, 200817 yr would this paired with an Alpine iDA-X100(ipod deck) be a good match for processing if I wanted to run 2 or 3 way active? any thoughts from people who have or is currently running this eq.http://www.sonicelectronix.com/item_6358_A...EQS+-GRAY-.html Edited September 18, 200817 yr by nickeveready
September 18, 200817 yr Author don't all answer at once!! Edited September 18, 200817 yr by nickeveready
September 18, 200817 yr http://www.sonicelectronix.com/item_13554_...ontrol+DQX.html - eq and 3 way crossover -active digitalhttp://www.sonicelectronix.com/item_7197_A...OR-+WHITE-.html -eq and 2 way xover -active analog
September 20, 200817 yr Lots of wasted bands of equalization with that processor installed after the crossover. Consider that every band below a HPF and above a LPF is not doing anything and it should quickly become apparent that there isn't a lot of use for that processor in a high end system using active processing. It has its place, but not in a 3-way active system.
September 22, 200817 yr Author so what are some good processors out there that can handle the job? as far as alpine goes the only option i have with them is the Imprint(pxa-h100) Edited September 22, 200817 yr by nickeveready
September 22, 200817 yr Author The imprint is a big joke. If you want an Alpine processor, get the H701.don't think it's compatible with the ida-x100..i really want to get that hu
September 22, 200817 yr If you want to run active and are putting in a screen up front, you should really do the H701 but yes you will need the 205/505. Time to make the choice, a nice active install or that headunit. Sure you could still buy a H701 and a RUX to control it, but that seems rather stupid considering you don't have the screen yet.
September 23, 200817 yr Author If you want to run active and are putting in a screen up front, you should really do the H701 but yes you will need the 205/505. Time to make the choice, a nice active install or that headunit. Sure you could still buy a H701 and a RUX to control it, but that seems rather stupid considering you don't have the screen yet.the ida-x100 is the ipod hu not a screen, though it does have a screen on it. but i see what you mean
September 23, 200817 yr so what are some good processors out there that can handle the job? as far as alpine goes the only option i have with them is the Imprint(pxa-h100)The H100 can do a 2-way + sub setup. I'm not sure how you can control it completely.
