Posted September 23, 200818 yr Hello, I am going to be putting a new setup in my toyota celica. I am going for spl in this setup. budget is 1000 dollars for the amp, subs, and the box. any suggestions are greatly appreciatedthis is the space i have to work with:
September 24, 200818 yr Author Well, I'd rather not remove the seats. Any ideas for just the trunk area?
September 25, 200818 yr For the amp i would go with a sundown 1500dhttp://www.db-r.com/sell/store/index.php?productID=151$335Depending on trunk space maybe a fi bl 15 with the flatwind and cooling $299or two fi SSD 12's $388or 15's if you can fit them$418That should leave you with money for your box and sound deadening, maybe another battery
September 25, 200818 yr Author I like that idea, but I was thinking about doing 2 Fi Q's Sealed with this amphttp://www.hifisoundconnection.com/Shop/Co...id/0/rid/123284Do you think that amp would be a waste of money?also for a sealed box, is it ok to buy a pre-fab box on ebay or somewhere? I know that is a dumb question but I was just wondering because there isn't as much involved in a sealed box as there is in a ported
September 25, 200817 yr That amp compared to the Sundown would indeed be a waste. Two Q's sealed will be just fine in a prefabricated box on that power.If you are set on just purchasing a box rather than building it yourself (very easy for sealed), then make sure the one you buy is made out of 3/4" MDF and has sealed joints.
September 26, 200817 yr Author Ok just ordered the 1500d do you think I should do 2 ssd's or q's of that power?
September 26, 200817 yr if your going for SPL get a single bl 15 and spend the extra cash on a good ported box. you dont have to do this, ut with your goals in mind i think you will be happy.
September 26, 200817 yr You can do either one. If you do the Q's and decide its not loud enough for you, you can always add another 1500D.
September 26, 200817 yr Author Haha well I like how sealed sounds and I think ill go with the ssd's because of the price
