Posted October 1, 200818 yr I just purchased two Boston Acoustic G512-44 12"s for $400 shipped in a closeout sale from Crutchfield. I'm a link! Their specs are...RMS Power Range: 100-450w (225w per voice coil)Peak Power Range: 900wImpedance: 4 ohmsSensitivity: 94.3 dB at 2.83 volts, 87.2 dB at 1 volt Frequency Response: 20 - 350 HzMin. sealed box volume: 1.00 cu. ft.Min. ported box volume: 2.00 cu. ft.Mounting depth: 7-3/8"I picked these up because they're CHEAP & require a small enclosure; (I want to keep max trunk space.) I've heard clips of them & they sound crisp & hit decently. Here's a guy with two 10" BA G5's in a car Waaay bigger than my 2-dr '93 Civic..10" G5's, clip 1. 10" G5's, clip 3My question is, based on their specs, what are some well-matched amps I should look at? I'm a dumb n00b so any help is appreciated! Thanks, Al.
October 1, 200818 yr Author Well, doing your own research never hurt.. unless its on DIY surgery or something. I found the amp that perfectly fit my application so I bought it! Click to see more! I hope its as good as they claim!
October 1, 200818 yr I'm not too familiar with the G series amp, but I do like their slash series. Should be a good match.
