Posted October 2, 200816 yr I am going to Gain match the Amps using a Dmm & an O-scope, anyone done this ? have any input on how to get the most outta the amps without Overdriving them ???just want to do it different than Strappedany constructive suggestions or input is welcome
October 17, 200816 yr Just did a friends 01' S-10 Blazer. We started at the head unit and found where that started to clip and then set each amp tweaking and adjusting crossover points to find where the sine wave didn't clip. We used the Rockford Fosgate 3Sixty test CD. We used the 0db gain and -5db gain and found a happy medium and went from there. It gave my friend a sense of relief knowing he wouldn't overdrive his speakers... Word of advice, make sure you have a head unit with remote and set it to track repeat while setting and make sure you have closed windows and doors as the tones get very irritating.... Hope this helps. Im sure somebody has more info then I have given.Good luck.
