Posted October 10, 200817 yr Admin SSA has now got them!The SAE-1200D is the first in the new generation of "SAE" line amplifiers from Sundown Audio designed to offer the best value possible. The SAE-1200D is designed to produce it's full 1200 watts of rated output at 12.8 volts! As with our SAZ line sound quality was just as much concern as power output so the SAE-1200D will not disappoint in this regard. The SAE line comes with the same warranty and service that our customers have come to expect from Sundown Audio, all at a more affordable price than ever.SPECIFICATIONS:1200 x 1 watts @ 1 ohm600 x 1 watts @ 2 ohms300 x 1 watts @ 4 ohms0.153v - 5.6v adjustable input sensitivity15 Hz - 250 Hz Frequency Response> 90 dB S/N Ratio4-Way Protection Circuit (Thermal, Overload, Speaker Short, and Over Current)50 Hz - 250 Hz adjustable 12dB Low-Pass Crossover15 Hz - 50 Hz adjustable 12dB Subsonic Filter0 or 180 degree adjustable phase switch0 - 12 dB adjustable bass boost with 60 Hz center frequencyWired Remote Control unit included5x 30 Amp Internal Fuses17" L x 10.6" W x 2.2" H$499 US Dollars - MSRP
November 24, 200816 yr Should be a hot seller QFT, great price great product. Edited November 24, 200816 yr by 5.4SPL
