Posted October 30, 200817 yr what is the difference between the dual 1 ohm or dual 2 ohm on the btl's? is it just what the sub can handle, and can be wired down and witch is better the 1 or 2? Edited October 30, 200817 yr by denim spelling of model
October 30, 200817 yr What coil option you want will be dependent on what amp you are using. If you want a 1ohm load, get the D2 and wire it in parallel. If you want a 2ohm load, get the D1 and wire it in series. There is a nice tool on www.the12volt.com which does the wiring for you. What amp are you running/plan on running?
October 30, 200817 yr Author icic, i have my amp down to 3 options, ive heard the sundown 3000d is good but i also have heard good stuff about these two....http://www.onlinecarstereo.com/CarAudio/Pr...ProductID=14753http://www.onlinecarstereo.com/CarAudio/Pr...ProductID=19320witch is the best choice for the btl 18?
October 30, 200817 yr the hk4000d not worth the money and for the price of the 2500 go to db-r.com and get a saz3000d get the d2 btl and make sure you have a good electrical system.
October 30, 200817 yr Author hmm seems like most ppl say go with the sundown.....whats so good about it? clean true power? what?
October 30, 200817 yr you made a mistake........ you said you already bought the btls yesterday....... if thats the case what ohm config did you buy>?
October 30, 200817 yr Author this is the d2's then right....the newest fi btl?https://ssl.perfora.net/www.ficaraudio.com/...view.shopscript
October 30, 200817 yr this is the d2's then right....the newest fi btl?https://ssl.perfora.net/www.ficaraudio.com/...view.shopscriptlol no... you have all those drop boxes so that you can custom build your sub,........ what did you choose?
October 30, 200817 yr Author dude....thats the same website as what i posted on here, lol.....so those are the d2's, lol.
October 30, 200817 yr nooo... all you did was sent me a link to the fi btl shopping list...... it does not show me the options you picked... infact it states d1..... eitherway... with dual 2 you will be able to strap 2 saz 3000d's on 2 btls d-2s and have over 6000 watts on tap.... in your pm to me you stated that your gonna take this to a shop to have it installed...... not a great idea but the part im worried about is!!! i asked you about battery space and you said they will take care of all that....... so your not shopping for your own batterys? you know you MUST have many batterys for these amps correct>?
October 30, 200817 yr Author yes, i was guestamating like atleast 4 yellow top optima batteries at the least???
October 30, 200817 yr you will need more then 4!..... i have 5 yellow top types and a h/o alt...... for 1 saz 3000d... i ran three yellows on one saz 3000d it did not work out.... look into powermaster the d3100.. you will need atleast 2 of those. and replace your front cell with a powermaster aswell... that will give you a good start....
October 30, 200817 yr D3100's are pretty badass batteries..Big Jon you dont think one wud do him fine even if he has one under the hood?
October 30, 200817 yr D3100's are pretty badass batteries..Big Jon you dont think one wud do him fine even if he has one under the hood?1 3100d on two saz 3000d's jacob recomends you use ATLEAST 1 d3100 for 1 saz 3000d.... so 2 saz3ks you should use ATLEAT 2 d3100's..... i found that my saz 3000d runs cooler stronger and longer with 250 amphours on tap. when i ran 150 amphours my amp would run hot, and protect on long plays, eitherway, if space as an issue... and money is not.. the powermaster d3100's is for you........ how many of them to run...... well lets see how many people chime in.
October 30, 200817 yr Author ok i have two questions now. so there isnt any other type of amplifier that can do as close as good of job as the sundown 3000d, while pulling less juice?and number two, if the awnser is no, is this the battery i need to buy...http://www.soundsolutionsaudio.com/zencart...products_id=106
October 30, 200817 yr the saz 3000d is a VERY efficient amp.... you must understand that it TAKES alot of power to MAKE alot of power. and yes you will need a FEW of those.
October 30, 200817 yr Author ok, good deal, man these 3000d's are gonna be BA, lol. I will purchase like 6 powermaster d3100's for 4 3000d's then, and it should be enough? i really wanna put 4 fi's in the back of this jeep and i beleive if i take out the back seats and dedicate the whole vehicle...that there will be enough space!
October 30, 200817 yr Author what math? like how much room does each 18 need aprx? math like that and add it up and see if it will go in the back of the jeep?
October 30, 200817 yr ive heard some bad stories of that onlincarstereo website. anyways. lucky you didnt order from there
October 30, 200817 yr ive heard some bad stories of that onlincarstereo website. anyways. lucky you didnt order from therei ordered my hu from there lol
October 30, 200817 yr i meant very expensive stuff like those amps he posted links to. Edited October 30, 200817 yr by RobClay
