Posted November 4, 200817 yr I noticed Mach 5 Audio is now offering a MJ18-PR. Are there more sizes to come? I dig the box Mark made with a IXL 15 and the MJ18-PR. Dreaming out loud. I'd like to build a box with 3 IXL 10's firing up and 3 rear firing 10" PR's for my stang. Hint, hint, make a 10" PR. Keep the excellent products coming.
November 4, 200817 yr how would the PR work in a car set up?The same way they work in HT the same concept is applied..
November 4, 200817 yr I noticed Mach 5 Audio is now offering a MJ18-PR. Are there more sizes to come? I dig the box Mark made with a IXL 15 and the MJ18-PR. Dreaming out loud. I'd like to build a box with 3 IXL 10's firing up and 3 rear firing 10" PR's for my stang. Hint, hint, make a 10" PR. Keep the excellent products coming.One problem I see with that would be you'd need 2x the swept volume for the PR's, which would mean six 10" PRs...besides, Seas already makes a 10" PR You could do it, but IMHO, it's impractical and not worth the extra expense over a traditional bass reflex for something like this...
November 6, 200817 yr Depending on the excursion capabilities of your active drivers, passives and planned input power, this will determine how many you will require. For example. you could squeeze two IXL-10's per one MJ-PR provided you don't drive the subs too much below the tuning of the box.But Jim is right, the general rule for passives is about 2x the cone area/throw to each active driver.Best,Mark
November 6, 200817 yr Author Depending on the excursion capabilities of your active drivers, passives and planned input power, this will determine how many you will require. For example. you could squeeze two IXL-10's per one MJ-PR provided you don't drive the subs too much below the tuning of the box.But Jim is right, the general rule for passives is about 2x the cone area/throw to each active driver.Best,MarkHey, now there's a thought. Two tens rear firing and an 18" firing up. I might just have to take you up on that.
November 6, 200817 yr Depending on the excursion capabilities of your active drivers, passives and planned input power, this will determine how many you will require. For example. you could squeeze two IXL-10's per one MJ-PR provided you don't drive the subs too much below the tuning of the box.But Jim is right, the general rule for passives is about 2x the cone area/throw to each active driver.Best,MarkHey, now there's a thought. Two tens rear firing and an 18" firing up. I might just have to take you up on that. I wouldn't have A PR up-firing because they tend to have a good deal of weight to them and would most likely cause the suspension to sag. My 1050g PRs sag is i even lay them on their back.Also in a car, I would think the PRs would have a lot of unwanted movement from the forces from turning and bumps in the road. Just my 2 cents
November 7, 200817 yr Excellent point on the car movement Todd. That never crossed my mind. A person would have to ensure the cabinet is sealed real tight to minimize such things.The weight thing is largely dependent on how strong/stiff your suspension is.
