November 7, 200817 yr i would stick to the other design. that chit is just weird looking seriously you would have no problems using the one larger port, it isn't gonna be crazy long
November 7, 200817 yr Yeah I don't know about all that. Just one port with the correct amount of surface area is what you will want.
November 7, 200817 yr oh and you are saying i will need the BIGGEST box possible to fit in the trunk? 2 12" BLs would be better in the biggest box possible for my trunk?What we are saying is if you have 5.0 cu ft net and if one 12 requires 1 - 2.5 Cu Ft per woofer and one 15 requires 2.5- 5.0 cu ft per woofer you are probably better off with the 12s...
November 7, 200817 yr Author Yeah I don't know about all that. Just one port with the correct amount of surface area is what you will want.cool, i think its a little bit less complex and more effective, so i will do that instead! well cant wait to get this system!!2 Fi 12" BL1 Sundown SAZ 3000D2 12" Ported Boxpartial electrical upgrade
November 7, 200817 yr Author oh and you are saying i will need the BIGGEST box possible to fit in the trunk? 2 12" BLs would be better in the biggest box possible for my trunk?What we are saying is if you have 5.0 cu ft net and if one 12 requires 1 - 2.5 Cu Ft per woofer and one 15 requires 2.5- 5.0 cu ft per woofer you are probably better off with the 12s...yeah thats what i realized too....id rather have 2 maxxed out 12s rather than 2 15's that sound like total chit....but again for a future install, i wanna upgrade to 2 12" btls, but all im focused on is what i am gonna get as my college acceptance present which is the 2 BLs =)
November 7, 200817 yr looks like a good setup good luck with it, i'm sure you will be happy with the results. start soon by ordering some deadener and 1/0 gauge now
November 7, 200817 yr looks like a good setup good luck with it, i'm sure you will be happy with the results. start soon by ordering some deadener and 1/0 gauge now x2You can also get really creative with sound deadening to reduce rattles. Rattling everything in your car will be cool at first, then it will get annoying and you'll start tracking them down
November 7, 200817 yr oh and you are saying i will need the BIGGEST box possible to fit in the trunk? 2 12" BLs would be better in the biggest box possible for my trunk?What we are saying is if you have 5.0 cu ft net and if one 12 requires 1 - 2.5 Cu Ft per woofer and one 15 requires 2.5- 5.0 cu ft per woofer you are probably better off with the 12s...yeah thats what i realized too....id rather have 2 maxxed out 12s rather than 2 15's that sound like total chit....but again for a future install, i wanna upgrade to 2 12" btls, but all im focused on is what i am gonna get as my college acceptance present which is the 2 BLs =)I wouldn't say "maxxed out" . More like "optimal" Usually maxxed is used in a situation where mechanical or thermal limits are being reached or when clipping begins to occur.
November 7, 200817 yr Author oh and you are saying i will need the BIGGEST box possible to fit in the trunk? 2 12" BLs would be better in the biggest box possible for my trunk?What we are saying is if you have 5.0 cu ft net and if one 12 requires 1 - 2.5 Cu Ft per woofer and one 15 requires 2.5- 5.0 cu ft per woofer you are probably better off with the 12s...yeah thats what i realized too....id rather have 2 maxxed out 12s rather than 2 15's that sound like total chit....but again for a future install, i wanna upgrade to 2 12" btls, but all im focused on is what i am gonna get as my college acceptance present which is the 2 BLs =)I wouldn't say "maxxed out" . More like "optimal" Usually maxxed is used in a situation where mechanical or thermal limits are being reached or when clipping begins to occur.yea very true...but u got the point =)
November 7, 200817 yr Author looks like a good setup good luck with it, i'm sure you will be happy with the results. start soon by ordering some deadener and 1/0 gauge now x2You can also get really creative with sound deadening to reduce rattles. Rattling everything in your car will be cool at first, then it will get annoying and you'll start tracking them downyeah there is this stuff that looks like aluminum foil in the front and duct tape in the back that i am gonna put all over the inside of the trunk to have clean sound coming out....thx for reminding me about that...do u know i site where i can get it for a good price cuz at the circuit city here it is 200 bucks for the entire trunk
November 8, 200817 yr http://www.raamaudio.com/cgi-bin/index.cgi?p=prget o roll and it will be enough to do your trunk well and probably the doors also. Most trunk kits are like 15-20 square feet max, so thats 3 times the material for less $$$
November 8, 200817 yr Author http://www.raamaudio.com/cgi-bin/index.cgi?p=prget o roll and it will be enough to do your trunk well and probably the doors also. Most trunk kits are like 15-20 square feet max, so thats 3 times the material for less $$$so this is the best one out there? i will get it then =)
November 8, 200817 yr http://www.raamaudio.com/cgi-bin/index.cgi?p=prget o roll and it will be enough to do your trunk well and probably the doors also. Most trunk kits are like 15-20 square feet max, so thats 3 times the material for less $$$so this is the best one out there? i will get it then =)"best one out there" is debatable. I prefer second Skin myself
November 8, 200817 yr and for a 1/0 wiring kit i would get this http://www.sonicelectronix.com/item_3935_Kicker+PKD1.html#and for your battery terminals go with these.. http://www.knukonceptz.com/productMaster.c...ery%20Terminalsthe ones im talking about are the *NEW* KonFused Negative Battery Terminaland the **NEW** KonFused Positive Battery Terminal
November 8, 200817 yr and for a 1/0 wiring kit i would get this http://www.sonicelectronix.com/item_3935_Kicker+PKD1.html#and for your battery terminals go with these.. http://www.knukonceptz.com/productMaster.c...ery%20Terminalsthe ones im talking about are the *NEW* KonFused Negative Battery Terminaland the **NEW** KonFused Positive Battery TerminalYou could find better deals that a whole wiring kit though.
November 8, 200817 yr ^probably like this. http://www.knukonceptz.com/productDetail.cfm?prodID=KLM-AK0
November 8, 200817 yr It's not the best, but it's very good and the price is great. As far as wire, i dunno if i would go with the KLM, but i like the Knu kollossus and kolossus fleks a lot.
November 9, 200817 yr hows the brand dynamat for the dampening mat?Good, but not that great. There is better out there...for much cheaper.
November 9, 200817 yr I saw a roll of 1/0 AWG for like 20 dollars on parts express on sale, i think it was only 20 feet or so. Welding cable is good too...makes you wonder what you are really paying for with "High End" cables.Welding cable is a car audio hero.
November 10, 200817 yr Dynamat is overpriced and you are paying for the name... IMO Good luck with the build, get some pics up when you start it.
