Posted November 6, 200817 yr Right now I am running 2 polk momo 12's single vc, in sealed 1 cube boxes behind my seat. I am thinking of switching to 1 12 in a ported box and adding 2 8's for some more midbass. I dont have the room to port both subs. The sealed box are fine but I listen to a wide range of music, sometimes they dont hit the low low notes as well as I want them. I was just wonder if there was any suggestions about the quality of sound or should I just suck it up.I dont want to cut the back wall or anything, though I am thinking about modding the rear speaker spots on the wall behind the door/ seat for the 8's. I have a good sound for the most part it s just hitting the hard low notes that I want to fill out some more, but I dont want to lose the tight hitting bass either. Thanks for any help
November 6, 200817 yr Do a ported 12" in back and build a custom center console and mount 2 8" up front into the console sealed.
November 6, 200817 yr Do a ported 12" in back and build a custom center console and mount 2 8" up front into the console sealed.DON'T do this unless you have the correct processing to run a 3-way Front stage.
November 6, 200817 yr If the 8's you want to add are midbasses in your front doors or kicks, , if your plan was to run 8" subs with a 12" it is a terrible idea. Sounds to me like your box is way too small which is killing your lows.
November 10, 200817 yr Author If the 8's you want to add are midbasses in your front doors or kicks, , if your plan was to run 8" subs with a 12" it is a terrible idea. Sounds to me like your box is way too small which is killing your lows.Ya the boxes are 1 cube, may just go with 1 12 in a bigger sealed box like a cube and a half and see how it sounds. If I still dont get what I want from it Ill port it out. The midbass would be in the back with 12's I was going to build kickpanels for some 6.5" and just leave it but I am not sure if I wanna go through the trouble of it. Sounds good the way that it is just does not hit the low lows. Ill keep you guys posted about the turn out.
