Posted November 6, 200817 yr Hello This is my first post here, I made a quick look ,it's interesting forum.However I want to ask about the specs of the SQ system and components?I have Car PC controlling my sound system which is:Car PC with Turtle beach and Creative Xmod USB sound cards.Rear - Infinity Reference 9613i 6"x9" 3-way car speakersFront - Infinity Kappa 63.7i 6-1/2" 3-way car speakersAmp - JBL CS60.4 4 Ch 240 Watt Full Range Amplifierwhat do I need to add/change to have SQ system?thanks
November 6, 200817 yr Placement of front speakers for better imaging, removal of 6x9s and adding a sub would be a good start.
November 6, 200817 yr Author Placement of front speakers for better imaging, removal of 6x9s and adding a sub would be a good start.I'm thinking about installing component speakers , still looking a good one.But as a beginner of SQ I want to know what specs I should look for? E.G freqs range , amp THD , etc.On the other hand having a car PC made me think about 5.1 system , I 'm thinking about having 2 component sets for front and rear and a sub as you recommended.but If the car PC will not give me the quality I 'm looking for I'll just connect the sound card to the HU AUX.
November 6, 200817 yr Drop the Coaxials. Pick up a set of separates, run 2-way active. Don't do anything with the rears.Deaden the entire car. Use one sub in a sealed or IB configuration.
November 6, 200817 yr Installation, installation, installation. Mediocre gear in the best install will sound better than the best gear in a mediocre install always. Get ready to spend some time in your car.
November 6, 200817 yr Author Drop the Coaxials. Pick up a set of separates, run 2-way active. Don't do anything with the rears.Deaden the entire car. Use one sub in a sealed or IB configuration.I don't understand what you mean by "run 2-way active"I have done the front doors only till now.what is "IB configuration"?
November 6, 200817 yr Author Installation, installation, installation. Mediocre gear in the best install will sound better than the best gear in a mediocre install always. Get ready to spend some time in your car. I totally agree installation may make the system perfect or damn bad.while surfing I found Zapco Symbilink , seems perfect I don't know it deserves or not, what do you think?
November 7, 200817 yr Drop the Coaxials. Pick up a set of separates, run 2-way active. Don't do anything with the rears.Deaden the entire car. Use one sub in a sealed or IB configuration.I don't understand what you mean by "run 2-way active"I have done the front doors only till now.what is "IB configuration"?Active speakers refers to not using the typical passive crossover in off the shelf component speakers. You instead use a crossever before the amplification and then send one amp channel to each speaker.IB is Infinite Baffle. Usually requiring less power but using your entire trunk as the enclosure.
November 7, 200817 yr Author Drop the Coaxials. Pick up a set of separates, run 2-way active. Don't do anything with the rears.Deaden the entire car. Use one sub in a sealed or IB configuration.I don't understand what you mean by "run 2-way active"I have done the front doors only till now.what is "IB configuration"?Active speakers refers to not using the typical passive crossover in off the shelf component speakers. You instead use a crossever before the amplification and then send one amp channel to each speaker.IB is Infinite Baffle. Usually requiring less power but using your entire trunk as the enclosure.you mean to go to active crossovers? please where can I find schema for the connection and what crossover do you recommend?I think I need to do some researches for the enclosure , I found that IB itself has sub-types.Sorry for too many questions
November 7, 200817 yr For a 2 way active setup you can use a headunit with built in crossovers like the Pioneer 880prs or the Alpine 9887. Do a search for active crossovers and come back with questions after the search instead of before
