November 11, 200817 yr it will most likely be louder firing toward the rear I would think so too... He could always do that and just drop the armrest to let more air flow through the car. But I'm not sure if that would make it louder or not =/
November 11, 200817 yr Author so the armrest thing is necessary....just have the box fire to the rear, have some dynamat in there (or something similar) and that would be my best option?
November 11, 200817 yr yes. but the armrest thing is not necessary but you can do it if you want. it wont hurt anything Edited November 11, 200817 yr by RobClay
November 11, 200817 yr so the armrest thing is necessary....just have the box fire to the rear, have some dynamat in there (or something similar) and that would be my best option?If it was my choice, that is what I would do. Also, instead of Dynamat, look into RAAMat and Second Skin. I'm going to start playing with a box now.
November 12, 200817 yr Author so the armrest thing is necessary....just have the box fire to the rear, have some dynamat in there (or something similar) and that would be my best option?If it was my choice, that is what I would do. Also, instead of Dynamat, look into RAAMat and Second Skin. I'm going to start playing with a box now.yeah that was the name i was lookin for raammat....i forgot it for a sec....ok thanks
November 12, 200817 yr I just drew up a box.I need to check the math on this still. It meets the minimum requirements and is tuned to 35Hz I believe. It's the best I can do at the moment.EDIT: Here is the sketch up file if anyone wants to check it out. http://www.sendspace.com/file/10ihk4 Edited November 12, 200817 yr by abxx
November 12, 200817 yr Author I just drew up a box.I need to check the math on this still. It meets the minimum requirements and is tuned to 35Hz I believe. It's the best I can do at the moment.EDIT: Here is the sketch up file if anyone wants to check it out. http://www.sendspace.com/file/10ihk4THANK YOU SO MUCH FOR THIS!....I WILL DEF SHOW IT TO THE PERSON WHO IS GONNA BUILD MY BOX, AND HE SHOULD BE ABLE TO DO THIS...THANK U!
November 12, 200817 yr I can play around with it a little more, but I don't have an awful lot of free time today.
November 12, 200817 yr Author I can play around with it a little more, but I don't have an awful lot of free time today.thats cool man, just whenever u can, id appreciate it, whenever u have time
November 12, 200817 yr That is about 1.8^3 per woofer. That is with the max dimensions you gave me, but I don't know how that is going to sound. It's right at the minimum recommendations.
November 13, 200817 yr Author That is about 1.8^3 per woofer. That is with the max dimensions you gave me, but I don't know how that is going to sound. It's right at the minimum recommendations.aite man thanks alot
November 13, 200817 yr mine is at 31 1/2 and gets plently loud high and low. I would just go to what FI recommends which is 32hz.
