Posted November 12, 200816 yr So, I'm about to order a lowering kit and found one, http://www.jegs.com/i/Ground+Force/476/9921/10002/-1#But, it's 2 door only, dumb question but, I've yet to find one for a 4 door. Would I be able to put it on my 4 door blazer even though it says 2 door? Speaking 2 door I'm guessing hass the exact suspension/frame etc as a 4 door?
November 14, 200816 yr Honestly, I wouldn't buy anything from Jegs, and I'd buy even less from Ground Force. I'd suggest looking at the Belltech lowering kit, part number 615 (no shocks), 615ND (Nitro 2 shocks), or the 615SA (better shocks). That is a 2-3" drop in the front (depending on motor), and a 3" drop in the back.
December 6, 200816 yr go to summit and get there belltech or JDM lowering coils and drop blocks. thats the cheapest but if u want to keep yer suspention as good as stock get the drop leafs and drop spindles. yeah man come on over to s10forum.com we love to helpthe coils and drop spindles will only work for a 2wd if u have 4wd just take out the tortion key bolts and u will have a drop of 2" right there and then get ya sum drop blocks and yer lowered a little Edited December 6, 200816 yr by lil_italy773
