Posted November 13, 200817 yr What is the minimum number of yellowtops needed to run a Sundown 3000d? I've still got the stock alternator in the Frontier and want to see what I can do. BTW the Opti 50C is up for sale.
November 13, 200817 yr What is the minimum number of yellowtops needed to run a Sundown 3000d? I've still got the stock alternator in the Frontier and want to see what I can do. BTW the Opti 50C is up for sale.how much for the 50c?
November 13, 200817 yr i ran three, with a 200 amp h/o..... it worked but the amp would run warm and hot in the texas summer.also with the headlights on or the a/c i was down to12 volts at redlights.... i have 5 now... and the amp is cool very kool offten my 4 channel is hotter, headlights a/c im 14 at stoplights now. i say 5.
November 13, 200817 yr Any idea what the stock alternator produces amperage wise?And you'll need to give us an idea how the 3000D will be wired... because if you plan on running that thing at 8 ohms.. you'll be fine
November 13, 200817 yr yea them batts are gonna drain eventually if u run it for a long period more than likely.
November 13, 200817 yr Author Any idea what the stock alternator produces amperage wise?And you'll need to give us an idea how the 3000D will be wired... because if you plan on running that thing at 8 ohms.. you'll be fine Stock produces around 60-70 amps-FAR from enough- and the amp would run at 2 ohms. Daily driver application@lower volume, with the occasional demo. Finding a H/O alt for this thing seems impossible because of the small size and it's practically under the engine in a VERY small space.
November 13, 200817 yr Author What is the minimum number of yellowtops needed to run a Sundown 3000d? I've still got the stock alternator in the Frontier and want to see what I can do. BTW the Opti 50C is up for sale.how much for the 50c?It's on ebay right now but I'm not seeing any bids yet, ending in 4 days. Going for $300.00 shipped US. Want to put this $ toward upgrades.
