February 7, 200520 yr Author I'm thinking of using a 4 channel amp to run my whole system.The amp I'm thinking of using will do 600 @ 1 Ohm into two channels bridged.Then I've got the other 75 RMS x 2 @ 4 ohms for the highs.Definately want to go ported, for output. Box wise, I was considering 4 cubic foot at 33 hz.
February 7, 200520 yr You're right on target there. Another amp can always be added if needed, but the Magnum will work just fine on 600 watts.
February 7, 200520 yr I had my Mag 15 running off of 600 watts for a couple months and it performed extremely well. You will be pleased, especially ported. Mine was sealed.
