Posted November 21, 200817 yr Could someone check and make sure this is right for me?:39.5 x 21x 20.25 box (outer dimensions, i'm using .75" mdf)4.5 x 19.5 port (10.57 in. diameter, if you need it)24 inch port lengthi got just a little below 33 hz. I just don't want to find out it's wrong after i make the cuts and all. Thanks a lot
November 21, 200817 yr Port displacement is 1.42 cubes.sub displacement?????? I'm guessing .2 cubes.Therefore, box volume is 6.4 cubes. tuned to 34 hz according to winISD.What's 10.57 in. diameter?
November 21, 200817 yr Author What's 10.57 in. diameter?On some of the formulas it asks for the ports diameter, so i put it in just in case.Thanks!
