Posted December 2, 200816 yr My 2005 civic has only a 70 amp alternator and I was wondering If I can run a 500 watt amp without problem? Will my lights dim at night?This will be the only amp running and I would do the big 3 Edited December 2, 200816 yr by Chrisilver
December 2, 200816 yr Should not be a problem.My cousin runs almost 1500 watts in his civic with the factory alt and a yellowtop.
December 2, 200816 yr Should be no probelm! Make sure you have a good solid ground. I would recommend running 1/0 gauge for the future when you upgrade.
