Posted December 5, 200817 yr Do any of you guys know what's the maximum unclipped output voltage for a PG tantrum 1200.1 at 3 ohms?
December 5, 200817 yr If it is a 1200 watt amp at 1 ohms it swings 35VRMSIf it is a 1200 watt amp at 2 ohms it swings 50VRMSIt will swing the same voltage at 3 ohms, or a little more due to the power supply capacity and output stage losses....This will also be the same voltage fully clipped or unclipped, it is the rail limits....If anyone tells you what they clamped it at, that doesn't help you.... That will all depend on thier vehicle electrical and if they really know they are checking it at 3 ohms.....
