Posted December 6, 200816 yr Ok Im looking on getting my amp for my door speakers..I only listen to rap and NOTHING else..I plan on using the Mach 5 Audio MLI-65 They say they are 100 rms at 4 ohm?Now the question is, Cud I wire them up into 2 ohm and just use a two channel amp ran at 2 ohms?Or shud I just buy the four channel amp and run them at 4 ohms?My amp choices that im stickign with are..Rockford Fosgate T4004Does 50 x 4 @ 4 ohms and its under rated..Or..Rockford Fosgate T3002Does 100 x 2 @ 2 ohms and its under rated..Not sure which to choose..And are those Mach 5 Audio speakers straight speakers to run?And other suggestions im open to but Im sticking to Rockford Fosgate for the amps.. Edited December 6, 200816 yr by ohhsosmooth
December 6, 200816 yr WudntUghh.....Yes, 2 of them would be 2 ohms....When you do run them at 2 ohms off your amp alot of things happen. Your amp runs hotter, is less efficient, has more distortion and losses dampening... All of this at the gain of a db or so. I don't like doing this..... I would run each 6.5" on it's own channel instead of combining them...What kind of crossover are you going to use? I assume active on these if you are running 2 ohm, or are you designing some passives?Remember if you have passives already that are for (1) 6.5, they will cut the lowpass frequency in half if you run a pair at 2 ohms....
December 6, 200816 yr Author To tell you the truth bro..I dont even knwo what active and passive is..Lmfao!I just figured I cud save money on wiring two speakers together at 2 ohms instead of 4 ohms..Then I guess ill go with the T4004 and run em all at 4 ohms..What kinda crossovers shud I get?
December 6, 200816 yr I don't know how you save any money by running them at 2 ohms...Do yourself a favor, research passive and active crossovers, mill around the ideas for a few days and then post a question..Please, do us all a favor and and quit writting words like "cud" "shud"... It makes you sound stupid, but I don't think you are... But when you are looking for informed, well thought out answers, at least attempt to post your questions that way...
December 6, 200816 yr Author Its sraight bro..Call me dum all you want..Or wait I sound dum..And saving money on an amp that runs only two channels at 2 ohms instead of 4 channels..Hmm..Think about it...Ohh wait maybe if you tookt he time to research what amps im talkin about maybe you wudnt cry and have a hissy fitIsnt that what this forum is about? To learn?Love people like you who dont try and teach people..And on top of it actually get pissed about someone who has never dealt with speakers and running an amp to them..But I'm sure I CUD find someone who will help me out..Not trying to be a an ass or anything but my post was kinda clear..I was asking what I shud do..All you had to say was run it at 4 ohms or 2 ohms..But before we start the drama on forums lets leave it at that..
December 7, 200816 yr But when you are looking for informed, well thought out answers, at least attempt to post your questions that way...It makes you sound stupid, but I don't think you are...But, whatever man.....
December 7, 200816 yr Ok Im looking on getting my amp for my door speakers..I only listen to rap and NOTHING else..I plan on using the Mach 5 Audio MLI-65 They say they are 100 rms at 4 ohm?Now the question is, Cud I wire them up into 2 ohm and just use a two channel amp ran at 2 ohms?Or shud I just buy the four channel amp and run them at 4 ohms?My amp choices that im stickign with are..Rockford Fosgate T4004Does 50 x 4 @ 4 ohms and its under rated..Or..Rockford Fosgate T3002Does 100 x 2 @ 2 ohms and its under rated..Not sure which to choose..And are those Mach 5 Audio speakers straight speakers to run?And other suggestions im open to but Im sticking to Rockford Fosgate for the amps..Dude, like cud you just buy some coaxials for front and rear and use the built in crossover in the T4004? Wire it up at 4 ohms per channel. It shud be just fine. Not trying to be dum, but maybe you cud tell is what your goals are besides listening to rap. like subs, HU, sub amp. A little more explaining on your end and alot of us could help more.....Just a suggestion!
December 7, 200816 yr Guys please. No more swearing at people in this thread.If you want to help the OP good, if not, leave it alone.
December 7, 200816 yr Its sraight bro..Call me dum all you want..Or wait I sound dum..And saving money on an amp that runs only two channels at 2 ohms instead of 4 channels..Hmm..Think about it...Ohh wait maybe if you tookt he time to research what amps im talkin about maybe you wudnt cry and have a hissy fitIsnt that what this forum is about? To learn?Love people like you who dont try and teach people..And on top of it actually get pissed about someone who has never dealt with speakers and running an amp to them..But I'm sure I CUD find someone who will help me out..Not trying to be a an ass or anything but my post was kinda clear..I was asking what I shud do..All you had to say was run it at 4 ohms or 2 ohms..But before we start the drama on forums lets leave it at that..You'll need to be a little more respectful around here if you expect to keep getting your questions answered.Please improve your grammar as well.
December 7, 200816 yr and you still haven't told us whether you are running 2 or 4 of the speakers If you're running one set, there's no way you can wire them to 2 ohms and use either a 2 channel or 4 channel at its best. It would be silly to wire your speakers from the two sides of your car in parallel onto one channel of an amp. Not only would it mess up your imaging, but it wouldn't give the speakers more power because they'd just be splitting the amp's power anyways.Assuming you are using one driver per door, you can use either of those amps. Either wire them straight to the 2 channel with one side per channel at 4 ohms or get the 4 channel and bridge it and run one set of bridged channels to each side, again at 4 ohms. Personally I'd do a 2 channel for easier installation, but you may want to get a more powerful 2 channel.
December 7, 200816 yr Author Ok im buying the T4004..Ill be running a speaker in each door panel, So i'll need two sets..Right now I'm only going to be running an 18" BTL with a T20001bd..I listen to only rap and nothing else..The only thing im looking for is just loud and clean sound..Im really only looking to spend around 300-350$ for both sets at the most..I was just looking at the MLI-65's cuz they look decent and cheap..Is this a more thought out post of goals and what not?
December 7, 200816 yr Its sraight bro..Call me dum all you want..Or wait I sound dum..And saving money on an amp that runs only two channels at 2 ohms instead of 4 channels..Hmm..Think about it...Ohh wait maybe if you tookt he time to research what amps im talkin about maybe you wudnt cry and have a hissy fitIsnt that what this forum is about? To learn?Love people like you who dont try and teach people..And on top of it actually get pissed about someone who has never dealt with speakers and running an amp to them..But I'm sure I CUD find someone who will help me out..Not trying to be a an ass or anything but my post was kinda clear..I was asking what I shud do..All you had to say was run it at 4 ohms or 2 ohms..But before we start the drama on forums lets leave it at that..You'll need to be a little more respectful around here if you expect to keep getting your questions answered.Please improve your grammar as well.x 2.. there is a lot to learn from people on here. and everyone is willing to help as long as your respectful and willing to listen
December 7, 200816 yr Alright, you really want to use those 6.5"sWhat tweeters did you pick and have you decided and/or researched if you will go active or passive?As soon as you make a choice, you can get help with your execution.The overall impedance you will have (2 or 4 ohms) is pretty much a mute point, or in other words, it won't matter at all.... You gain almost nothing by running an average 2 ohm set over a 4 ohm set....
December 8, 200816 yr What tweeters did you pick and have you decided and/or researched if you will go active or passive?That was going to be my next question as well.
December 11, 200816 yr "Cud" isn't a word...Yeah it is.http://www.bigsiteofamazingfacts.com/why-d...ow-chew-its-cudNothing to do with "could" however. C'mon now.....how hard is it to type two extra f*cking letters......... Edited December 11, 200816 yr by MikeS
December 11, 200816 yr dum... thats so funny. you should go passive and we can all save alot of time here.
