Posted December 6, 200817 yr Are these amps underrated?Anybody have a birth sheet or a estimate of what the 750.1 will really do @2ohms?
December 6, 200817 yr i own a zx1000.1 bithsheet says 1165@ 2 ohms ive heard of zx750.1 putting up 8-850+
December 6, 200817 yr Author alot of people say the zx series from kicker are very underratedFast response, I was really looking at the zx750 for my SSD over the Hifonics because I have heard bad stuff about Hifonics.
December 6, 200817 yr Author i own a zx1000.1 bithsheet says 1165@ 2 ohms ive heard of zx750.1 putting up 8-850+Wow your from Crestview?My dad works over there all the time, I'm in Pensacola right now.But anyways I think I'm gonna get the zx750 over the bxi1208 Edited December 6, 200817 yr by ShaneSauce
December 6, 200817 yr ubid.comgood price on refurbs in your on a budget. i wana get my hands on a 750.1 some day...heres a 1000.1link
December 6, 200817 yr Wow your from Crestview?My dad works over there all the time, I'm in Pensacola right now.But anyways I think I'm gonna get the zx750 over the bxi1208do it
December 6, 200817 yr I can get a refurb for a little cheaper.Would I be okay with a refurb?where did u find one cheaper? ebay?i like ubid because of the extend warrenties u can get.
December 7, 200817 yr Are these amps underrated?Anybody have a birth sheet or a estimate of what the 750.1 will really do @2ohms?mine is rated 929 @ 2ohms and its the 2008 version if that helps any
December 7, 200817 yr IMO Birth rating don't mean anything, I highly doubt that they test every amp, more likly 1 out of every hundred or something like that, I ordered 4 zx2500's they arrived with sequential serial numbers and exactly the same birth rating, I would assume that they test one or two out of every run and give all the amps in that run the same birth rating.Kicker amp do put out more than rated power, I'm just saying don't rely on the birthsheet,My tested ouput on my zx2500's were not the same... on the four that birthed the same, I tested within a 200watt span of difference, the median being roughly 2650 @ 2 ohm and a little over 2700@1 ohm, the 750's put out well over 800 watts @2, at one ohm I've tested one at over 900 watts..good amps but I wouldn't shop around via birthsheet ratings..
December 9, 200817 yr The only one I have in stock is 949 watts at 2 ohms and 14.4volts. If that helps.
December 9, 200817 yr ***all 08 amps seem to "birth" higher than any other year... I believe they use to test at 12.4v
