Posted February 11, 200521 yr hey i was wondering were is a good place to buy fiberglass and everything else i need does LOWs have it
February 11, 200521 yr Lowes, Home Depot, or any body shop that'll sell you equipment/supplies. Boat shop's are handy too. There is the internet for the extra stregnth mats & weaves if you really can find them locally (as in my case).
February 12, 200521 yr fiberglast.com is another goody.<{POST_SNAPBACK}>Home Depot. Lowes doesn't carry it (around here). Get the mat, do not get the cloth because it is VERY thin at Home Depot.
February 12, 200521 yr I wouldn't listen much to Nick on fiberglass-related posts.....I don't think he's used it much. Definitely go mat and not cloth. Or, go cloth and resin, and then find out that mat was the way to go. It's whatever order you'd like to go in really.
February 12, 200521 yr I myself find it much easier to use the cloth for sanding purposes. The cloth is generallt going to provide a smooth surface once the resin is cured. Of course I also like it because I picked up a ton of it off Ebay really cheap.
February 14, 200520 yr I wouldn't listen much to Nick on fiberglass-related posts.....I don't think he's used it much. Definitely go mat and not cloth. Or, go cloth and resin, and then find out that mat was the way to go. It's whatever order you'd like to go in really. <{POST_SNAPBACK}>way to crawl out of the shadows josh . where you and the mrs's been hiding? give me a holla some time also, hows your weiner doing?
February 14, 200520 yr Author thanks guys o and i have a nother Q i have a 2004 dodge ram 1500 4 door i want to make a box that goes under the seat u think i will have any truble with SQ and i am only going to get one D2 12 and put it on the left side of my truck everyone is telling me that it will sound like it is coming from the back left and that the sound will be muffaled i am also going to port it iam just haveing truble with how to figure how many cubes becouse if any of u have ever seen a 2004 dodge ram under the seat its not flat it has cubbys very hard if any of u have any iders lol just tell me having truble o and the new D2 is the sexyest thing ever
February 14, 200520 yr Just because the sub is mounted on side of the cab doesn't mean it will sound muffled. Also, the mounting depth on these puppies isn't shallow so I don't know how you're going to fit it under the seat.
February 14, 200520 yr Bass= non directional ( around 80HZ-)EH, lower than that. SUB-bass is non-directional I can clearly point out my sub crossed anywhere over 55 or so. Could be just me though. Everyone's ears are different.
