Posted December 11, 200817 yr all stock, gains set with an Oscope so clean signal. i will update with numbers when i get around to doing the math-Drew**edit vid is a "tour" of my recent additions along with good winshield flex at the end, woofer porn to come later Edited December 11, 200817 yr by Noobtastic14
December 12, 200817 yr Wow man thats cool I just got done ordering4 lvl-3 DC 15's with the upgraded 2ohm voicecoil, Iv thought about getting that Crunch ampbut I think im gona go with the Audioque 3500Cool setup.... How do you like that amp anywaycuz I know the Crunch can be had for about halfof the price of the Audioque 3500d
December 12, 200817 yr Author i'm not getting 3kw of clean power, but i would run a pair 3s conservatively on one in the right box. All the DCs are solid products and will take some heavy abuse-Drew
December 12, 200817 yr i'm not getting 3kw of clean power, but i would run a pair 3s conservatively on one in the right box. All the DCs are solid products and will take some heavy abuse-DrewWhat voltage and current did you measure right before clipping?
December 12, 200817 yr DAMN DREW! looks like your windsheild is going to blow off lolYour car takes alot of abuse haha, I feel sorry for it.
December 12, 200817 yr Author i'm not getting 3kw of clean power, but i would run a pair 3s conservatively on one in the right box. All the DCs are solid products and will take some heavy abuse-DrewWhat voltage and current did you measure right before clipping?haven't gotten around to getting the #s yet. I just got my rockford 360.2 test CD back so i'll be setting it with a -5db overlap here shortly and will update with numbers then.How is your electrical???70A alt + 110A alt two redtops big 4/5 in 0ga 12.2 at idle after ~5min of blasting and 14.x constant while driving.bats sit at 14.4 at idle system off at 13.2 on 1A trickle chargerand 12.7 just sitting-Drew
