Posted December 19, 200817 yr I recently took out my big heavy soundsystem due to the weight in the back causing traction issues up front.( gonna fix that this summer i hope), but for now i took my two kinetic 1800 batteries out. I went out and bought a cheap battery maintainer thing from advanced autoparts, it says 1.5 amp maintain. My question is can i paralled the batteries together and hook both up to this one maintainer or would i need to get another. To me it seems fine, it would still be seeing 12v to maintain. Right?
December 19, 200817 yr I recently took out my big heavy soundsystem due to the weight in the back causing traction issues up front.( gonna fix that this summer i hope), but for now i took my two kinetic 1800 batteries out. I went out and bought a cheap battery maintainer thing from advanced autoparts, it says 1.5 amp maintain. My question is can i paralled the batteries together and hook both up to this one maintainer or would i need to get another. To me it seems fine, it would still be seeing 12v to maintain. Right?Is it a battery tender? If so you should not wire it together.. I would get one for each batt. My 2 cents
December 19, 200817 yr Author I recently took out my big heavy soundsystem due to the weight in the back causing traction issues up front.( gonna fix that this summer i hope), but for now i took my two kinetic 1800 batteries out. I went out and bought a cheap battery maintainer thing from advanced autoparts, it says 1.5 amp maintain. My question is can i paralled the batteries together and hook both up to this one maintainer or would i need to get another. To me it seems fine, it would still be seeing 12v to maintain. Right?Is it a battery tender? If so you should not wire it together.. I would get one for each batt. My 2 centsyea, but i think battery tender is just a brand of battery maintainers.i could get another, but how im seein it is all its gonna look like a 3600amp 12 battery to the maintainer.
