Posted December 20, 200816 yr I plan to wire my sub to my amp like this,My question is, would it be the same if i ran 1 positive wire out of 1 positive terminal on the amp into 1 positive terminal on the voice coil and the other positive terminal on the amp to the other positive terminal on the other voice coil and the same for the negative?
December 20, 200816 yr it would be a waste of wire to do that. Its easier to just run the jumpers from each voice coil to another
December 20, 200816 yr it would be the same the outputs are the same post just two hookups so it will still show up as the same load to the amp
December 20, 200816 yr no telling he did not list the v/c value, its weird i see you give EVERY one advice, but in the last week i have seen you ask THE sillyest questions. how to run an amp kit, and how to wire your sub to your amp.
December 20, 200816 yr ok i saw in your other thread you have an icon D2. heres some wiring options.1ohm load4ohm loadshould be very simple.
December 20, 200816 yr haha times twooooo what bigjon said, are you just trying to wire parallel for 1 ohm? that amp has internally bridged channels.
December 21, 200816 yr Author Can you guys not see the picture in my first thread? I know how to wire my amp to my sub....... I'm asking if i can do it the way above.
