Posted December 22, 200816 yr ok, if i bought about 20 Feet of KnuKonceptz 1/0 Gauge Power Wire and 6 Directed Electronics 63205 1 / 0-gauge Ring Terminalswould that be all i need to do the BIG 3?
December 22, 200816 yr Author to get this straight.....#1 Pos of battery to Pos of Alternator (do i add to the old wire? or replace the old?)#2 Neg of battery to Chassis (self explanitory)#3 Engine to Chassis (on the engine just any exsisting bolt?? on chassis same place as #2???)Hyundai Sonata 2000 Edited December 22, 200816 yr by sandsnip3r
December 22, 200816 yr sound good. id remove the old alt to bat but i dont think you need to i just looks cleaner with the one.
December 22, 200816 yr to get this straight.....#1 Pos of battery to Pos of Alternator (do i add to the old wire? or replace the old?)#2 Neg of battery to Chassis (self explanitory)#3 Engine to Chassis (on the engine just any exsisting bolt?? on chassis same place as #2???)Hyundai Sonata 2000dont remove the old wired from the alt, just at the 0 guage, i put 0 guage from my alt to my chassis too.
December 22, 200816 yr for your engine ground you can use your bracket that holds your alternator in place
December 22, 200816 yr Author http://cgi.ebay.com/KnuKonceptz-Metallic-B...A1%7C240%3A1318http://cgi.ebay.com/Stinger-Gold-0-Gauge-A...A1%7C240%3A1318$61.25 for parts, shipped
December 22, 200816 yr for your engine ground you can use your bracket that holds your alternator in place thats wat i used to ground my alt,
December 22, 200816 yr http://cgi.ebay.com/KnuKonceptz-Metallic-B...A1%7C240%3A1318http://cgi.ebay.com/Stinger-Gold-0-Gauge-A...A1%7C240%3A1318$61.25 for parts, shippedcloser to 100% copper wire is better
December 22, 200816 yr Author yeah....http://cgi.ebay.com/Rockford-Lightning-Aud...A1%7C240%3A1318will that work?can i get by with 7 ft?
December 22, 200816 yr yeah....http://cgi.ebay.com/Rockford-Lightning-Aud...A1%7C240%3A1318will that work?can i get by with 7 ft?look for the seller uneeksupply, i think thats the name, thats were i got my wire
December 22, 200816 yr Author http://cgi.ebay.com/0-GAUGE-RED-POWER-WIRE...A1%7C240%3A1318thats good?
December 22, 200816 yr Author if i got the 1/0, that would work?and if im running a 2200 watt amp, can i run 4 gauge?i had a 1900 watt amp on the 4 gauge before...
December 22, 200816 yr if i got the 1/0, that would work?and if im running a 2200 watt amp, can i run 4 gauge?i had a 1900 watt amp on the 4 gauge before... that 0 would work
December 22, 200816 yr Author for what? to replace the 4 gauge? or can i just leave it?and if i need to change it.... what about the fuse? just transfer it to the 0 wire?
December 22, 200816 yr If it has 1/0 gauge terminals I would sue zero gauge. If the fuse holder accepts 1/0 gauge you can reuse it as for the fuse itself, you fuse for the wire. 1/0 = 300 amp
December 22, 200816 yr Your amp try to compensate for the low voltage by working harder, and it will overheat and die in the long run (my friend killed his hifonics 1608 with voltage issues). Below 12 would be low with 13.8 - 14.4 being ideal.
