Live in Texas and the temp can range from 95 to 105 from May to middle of September. Just want know how to keep my amps cool from running and the temp being so high?
Unless you bump at full tilt you should be fine.
My 4000D ( has temp readout) was showing 130*F inside my burb, not even running, just sitting there
liquid cooling----electralite free water and a CPU pump will work with a AC/DC converter------at least this is what I am doing in my next install.
  • 1 month later...
:slayer: fans are ur best bet. cheap, easy to hook up, and u could have a cool switch for 'em......
Yep, 2 fans pushing, 2 fans pulling. Cheap, easy and effective.
What part of Texas are you in? I live in dallas and I feel you on the heat, but I havent had a problem yet.
